Engine Brand VS Thread
FatCat
2 stroke Addict!
Ottawa, IL
Key words " never used one" Don't dis clones untill you have used then. For a $100 they're great. Mine is still going strong after years of constant abuse, all while running at 6k rpm. Most clones are almost exact replicas of gx200's, right down to part compatibility. The only difference with clones is the bore size, with the exception of the predator. I believe that they changed the stroke with that one.You are getting the years of r & d from Honda because they are essentially honda's, just made with cheap Labour.
I'm glad you've had good luck with them. Like I said, if they are anything like a Chinese quad they are junk. I wrench on local peoples ATV's on the weekends. I've worked on a dozen or more Chinese ATV's and now I just send them packing as soon as I see what it is. Don't believe me... Buy one and have at it. Parents buy this junk for there kids and have terrible experiences. It sours people away from a hobby that I love. I don't like that. Don't like it at all. As for these chinese Go kart engines. I've never worked on one. Never even seen one in person to be honest but I'll never use one. Why would I. I payed $40 for a 16hp Briggs v-twin that runs like a Rolex. I thought that was a smokin deal but I could find a 5hp Briggs about any day of the week for $100 or less. It just doesn't make sense to me. Now if these "clones" are all a guy can afford I'd tell them to go for it. A toy is a toy but it would be my last option. Actually not even an option. I'd modify something(anything) else to work.
crazyman
Yorkville Il
Don't forget about Kawasaki. They make good small engines too. I have a liquid cooled 27hp Kawi that I swapped onto an older Simplicity. Runs like a r***d ape.
FatCat
2 stroke Addict!
Ottawa, IL
Also guys let's talk about this cheap labor. Often cheap goes hand in hand with unskilled. I'll save the cheap labor for the person making my fries or the kid who mows my lawn. NOT my engine builder. Also that cheap labor is taking a job from someone like me. I can't support my family on $9 an hour. Sorry! There's a lot of that in my area. 4 and 5 families living in one house. They'll work for less than our legal minimum wage. I'm not going to live like an animal. I'm very fortunate to have a great job in a busy industry for a fair wage. Thankfully they don't turn $9hr people loose with equipment that can kill people. Ill apply myself and put more effort into what I do than this cheap labor will. The best at anything love what they do. That's how and why they became the best. Cheap labor doesn't take any pride in your engine. They're just collecting a check.
FatCat
2 stroke Addict!
Ottawa, IL
Note: I'm not saying whoever is building Briggs and Stratton engines are talented engine builders. I will say 9 times out of 10 the better paid engine builder has more skill. that's how they got the better job.
buddyochoa
Not Senior Yet
Thorn Hill, TN
Now I'm not sure if the lower priced clone operations have all of the tools and such that Briggs or Honda has. They may be doing this all with basic hand tools.
fowler
Bullsbrook West Aus
It is more the materials
Low grades of steel or using plastic in place of sheet metal
And the tolerances of quality control
Honda won't send anything but a perfect motor out to a customer because there biggest asset is there reputation
The clone makers have no reputation so there biggest asset is price
Sometimes u get a good fully setup clone
Sometimes it requires adjusting
And occasionally u get junk
But because they are so cheap a store will exchange because again the stores biggest asset is the reputation
buddyochoa
Not Senior Yet
Thorn Hill, TN
Though it is important to remember also, we may pay lower then minimum wage to 3rd world countries workers, but $7USD is worth a lot more there as well.
buddyochoa
Not Senior Yet
Thorn Hill, TN
Anyone know the average rebuild kit cost for a 12hp engine? I know it will vary depending on manufacturer, just about what it would cost for one.
K-TRON
When it comes to air cooled gasoline engines, nobody builds em better than Wisconsin. I own over 30 Wisconsin heavy duty industrial air cooled engines, and they will run through hell and back and just keep on a running as long as there is a fuel supply nearby. Their motto is "most horsepower hours" and that is a fact not a statement. They will run in excess of 20,000 hours only on standard maintenance before needing a rebuild, which Kohler, Briggs, Tecumseh and Honda couldnt attest to. Why do they last so long????, they have full pressurized oil lubrication, removable bearing inserts, cast iron blocks/cylinders/heads, forged steel rods, stellite exhaust valves, valve rotators, impulse coupling magneto's, and they run big name carburetors, Zenith/Marvel Schebler. The only utility engine which comes close in durability are the old K series Kohlers, but they will barely brake the 5,000 hour mark before needing a rebore. Honda, bah you'd be lucky to get 3,000 hours out of one before it'd throw a rod or take a dump. As much as I love Wisconsin engines, I wouldn't want one on a kart pounding away next to me. They are incredibly heavy, and when they are loaded up they will make the ground shake!!! That doesnt say I do not use em for similar tasks. I have a 12.5hp single banger AGND on my homemade scooter. At 2200rpm it does 58mph. Power is transmitted through a Twin Disc power take off clutch. The engine weighs in at 220lbs and makes 28lb/ft of torque, enough to get the load moving on any terrain. I plan on building a hot rod cub cadet 100 with a VG4D Wisconsin engine next summer. 37hp and the right gears ought to get it moving.
A friend of mine had a homemade kart back in the 60's with twin Mercury DA-211 chainsaw engines on it, ported and governed to 6500rpm. Each dyno'ed out at 24.5hp from what he said. He remembers it going incredibly fast, 110mph, but he long since sold it as he is 67yrs old now. I have the same engines on my two man chainsaws and they are incredibly powerful low rpm 2 cycle engines. There design and build quality is second to none. Manganese bronze rods, pistons and top of the line Alcoa Aluminum everything else. If I was building a cart today two Mercury engines would be my engine of choice.
Chris
jamyers
Buffalo Gap, TX
Threads like this are like "Ford vs. Chevy vs. ______" threads. Lots of opinions, some based on data, some based on experience, some based on hearsay - but the bottom line is that the BIGGEST factor in the durability, reliability, etc of any mechanical device is OPERATOR MAINTENANCE, and how you going to account for that?
Any terrifically-designed, -engineered, and -built machine can be turned into junk in seconds, and a clear-cut piece of junk will sometimes run for years.
Truer words were never spoken. This is why every time I hear somebody bad-mouth a Tec, I get my shorts twisted. SEND THEM TO ME! I don't have these problems...
...Then again, I maintain my stuff...
carter
I hear people badmouth the reliability of tecs a lot. I don't understand it, I change the oil every now and again, make sure my air filters are clean and my spark plugs aren't fouled up and she treats me right. Granted I've heard goot things about the '97-'01 HM100's
