Electrifying! (Well hopefully)
supermanotorious
Winchmaster 5000
New River, AZ
I ordered the replacement flywheel and charging coil for Predator generators to try in my winch build- 420cc Predator motor. The hope is to charge the battery. If this works, I bet we can run some lights off these engines. Fingers crossed that it will work. You know **** well I'm going to try it this weekend!
supermanotorious
Winchmaster 5000
New River, AZ
stomp on frogs and shove a crowbar up my nose! I pulled the fan cover off and immediately noticed a wire coming from behind the flywheel passing through the same square grommet that came with the replacement. I think these engines already have a charging coil!
Mine does! :mad2:
:feedtroll:
supermanotorious
Winchmaster 5000
New River, AZ
I don't know if it's safe to assume that an engine with electric start will automatically have a charging coil
---------- Post added at 07:26 AM ---------- Previous post was at 07:25 AM ----------
Now that I have an extra coil, can I add it and have additional "juice"?
BirdFanatic
Jonesboro Arkansas
(Generator motor) I know most of all generators charge batteries so there had to be something with this thread that was a little off. :D My motor is the same as yours (420cc 16hp ) so this thread had me scratching my head there for a few seconds going why would your motor be any different XD .
I would say "yes", if it had extra stud boss for attachment on the block. Kinda like an additional circuit to charge and run from.
I do; every electric start engine I've seen has a charging coil...
An electric start engine is useless without a battery; if the engine doesn't provide some way of charging the battery, it's rather pointless having the electric start mechanism, wouldn't you agree?
supermanotorious
Winchmaster 5000
New River, AZ
I'm not following you here, the ignition coil is on the "outside" of the flywheel, the charging coil is on the inside, why wouldn't I get voltage on the charging coil line?
maybe your reading it incorrectly?
the charging coils produce AC currents, if you try to read that in DC mode with a cheaper multimeter, you might end up reading zero voltage *shrugs*
(mine jitters when trying to read AC in DC mode.. basically a blinking minus sign)
Anyways, there should be a diode somewhere under some heatshrink..
chances are you read behind it (which indeed should be DC then)
if it's a single diode it's possible that reading the voltage behind said diode can cause a zero reading too;
the reason is simple:
half of the voltage and current is cut off, if the phases change too fast your multimeter might not be able to keep up updating it's display and you'll end up with a BS reading again.
best thing to do?
take a nearly discharged (say ~9-10V) battery and connect it, let it run for half an hour or so, and recheck the battery.
there should be a measurable increase in voltage (.5V depending on the battrey's capacity)
supermanotorious
Winchmaster 5000
New River, AZ
oh my Sid, I finally read your post correctly, I set the meter to AC and was getting about 16 volts at idle, I think this is the diode, and sure enough, on the other side, I get DC, about 6V at idle and 20V+ when revved, I learned something new today! So, if I wanted to add the other coil, I'd need to add a diode to convert to DC as well- correct?
looks like a diode symbol [ -►|- ] yes.. but I can't tell for sure from that angle ;)
Anyways, yes, you can add another coil (if there'enough room and mounting holes of course)
you could even add that to the same diode; but depending on the magnet configuration of the flywheel (even numbers), you might need to respect the phases and it can get messy..
it's indeed easier to add another diode, and join the two afterwards (parallel!)
