I've read that it may be possible to use an electric clutch from a car's ac compressor in a go kart
Supposedly, it does not engage until you gie it 2-3 amps from a battery (12volt i assume).
I plan on using a car battery anyways in my setup and i think that this 2 wire setup would be easier than rigging up the belt clutch setup..
They have to be pretty heavy duty due to the fact that they are used in cars and trucks. I guess it works by the electromagnetic field which to engage it pulls weights/magnets centrifically to the outer drum in the same way that a centrifugal clutch does.
Anyone have thoughts or experience with these?
