Electric choke
ghostdog
Has anyone ever setup an electric choke or some from of automatic choke on their kart?
I have an electric start motor that I activate from a panel next to the steering wheel. I would like to be able to adjust the choke from the seat at the very least but something automatic or electric would be ideal.
I don't mind spending a few dollars and my kart has a battery.
This is on a 7hp duromax engine.
*ryan
whynot just get a remote throttle cable
and hook it onto the frame somewhere by you
slide it foreword for choke on, slide back for choke off
simple
cheap
effective
no wiring involved
just a cable
Badot
I'd say either what was just said, or run a switch with something like a small model airplane servo on the choke lever.
Probably either springload the choke closed with the servo holding it open, then use a normal open-close switch, or you can go without the spring where you'd have to use a normally closed switch with two outputs to adjust the choke (either open or close it).
