Easy Way To Get Bits To Drill Main Jets
BrandonF260Rem
Central, TX
Every where I have read about drilling main jets has said get a numbered set from 60 to 81 or some where in that neighborhood. Here is an easy way to get those bits locally (normally).
Go buy a Oxy-Acetylene tip drill bit kit.
This kit comes with a small pin vise and bits from 52 to 74. Forney makes this little kit. Available at most hardware stores and welding shops for hand drilling SLAG out of a torch tip.
Tip Drill Set
machinist@large
West Michigan, 49331
That's actually a pretty good price. I personally have more than one item from the Forney catalog; their welding info handbook is a great reference for getting started in stick and gas welding, and their grinding wheels and sanding disks are good buys as well. I can highly recommend their wire brushes as well; you'll be hard pressed to find a stainless steel one most anywhere else outside of a welding supply house otherwise.:thumbsup::cheers2::popcorn:
