E175 scooter...how to test?
ghost civic
maine
I picked up a razor E175 scooter at a yard sale.
when I tried it, all I got was a "click" sound.
I assumed it was the batteries low (or basically dead) but when I put it on the charger it finished in less than an hour.
Taking it apart, the click sound is coming from one of 2 black bricks on the ECU.
What Im wondering...is could a bad motor cause the ECU to make the noise, or does that noise indicate that the ECU is bad? I only paid $10 for it and the batteries seem to be good...so if I only had to put $20 into it to make it run that wouldn't be bad.
ghost civic
maine
Try pushing it to get it going, the smaller 100 series were made to bevmoving first before kicking in
yeh, I figured that and tried. nothing. no noise from motor, only from the ESC. Clicks like a breaker.
Kinda wish I could test the motor. If I know for sure it works, then it would be worth $25 to buy a new ESC as that should be the problem.
ghost civic
maine
thank you for your suggestion...because of it I decided to search for the manual online.
I read it has to go 3mph before motor will engage...I tested it going just a touch slower.
However, once I got the motor to engage (which should mean the ESC is good) it quickly came to a stop which most likely means the batteries are crap. The stock charger gives a green light...but Im going to put them on my other charger and see if that makes any difference. If it doesn't, Ill have to buy new batteries...but at least I know what it needs and doesn't need now.
Thank you.
ghost civic
maine
I put both batteries on my charger,
then used a digital volt meter (from a power wheels project)
I got 13v on one but only 11.7v on the other.
ghost civic
maine
Those batteries can read full but still not handle a load on them. Just get some generic ones off ebay
yeh, bought some last night. $25 shipped.
Couldn't the one reading 13v be good...but the dead one preventing it from even giving 12v to the scooter? If it were two 12v batteries in parallel then I would think one being dead would still permit the scooter to get 12v....but since they are in series I would think one being dead would prevent even the good battery from providing 12v to the scooter.
Ill have to test it in a power wheels. It is 1/3 the capacity of a normal power wheels battery, but if it is good why not use it.
If a fully charged battery is reading less that 12v, it's dead & won't have enough amperage to complete the circuit, draining the other battery in short order...
On another note, I have an E150 which acts the same way; replaced the ECU, no change; replaced the throttle, no change; once I connected some known good batteries it was fine...
ghost civic
maine
that sucks you changed the other stuff first.
I might have done the same thing (bought new ECU) if I hadn't checked each batteries voltage with the volt gauge I had. That gave a story different from what the charger was saying.
I should have the new batts by the end of the week.
