Johnnyboy
Hey guys,
The past few months with my go kart have been very shaky. It started with a simple swap of the drive belt, which was soon followed by a replacement of the entire driven unit as well as the chain and sprocket. After completing that, it only took a few days to run into a severe idling issue which was eventually solved by a new drive clutch. Clearly, many things have been shifted around on the kart and my hopes were set on enjoying a stretch of smooth operation. However, I have noticed over the past day or so that my new driven pulley is not functioning as before. As I accelerate and max out the engine (a 6.5 hp Robin) it is quite clear that the two sheaves on either side of the belt are not spreading to allow the belt to ride lower towards the shaft. In essence, this causes the kart to always be in low-gear. Any others who own a kart that uses a TC have probably noticed a definite "change of gear" when accelerating, where the kart begins to move much faster. However, this transmission no longer takes place on my Manco Rattler. Any ideas as to what could be causing this issue?
(my finger is pointing to the hole where the spring is currently loaded in)
