driven pulley removal
bungee
i have 1985 honda odyssey fl 350 dune buggy. I am trying to remove a bad driven pulley on the transmission. I can not get it off, it wont come off with a puller tool, is there another way to get it off Thanks
firemanjim
Just kartin' around....
Houston Texas
Soak it with PB blaster or similar fluid. Repeat for a couple days. Then try again. Leave the pulley puller on it, under tension, next time, if it don't come off. Soak some more. Leaving it under load over night might let it free up on its own...
KartFab
Dallas, TX
You can also tap the driven unit while it's under tension.
Some pulleys have a slider weight that helps it break free.
Worst case scenario you use a thin blade metal cut off disk and carefully cut it off with an angle grinder.
bungee
i was told heating might ruin seals.Putting a puller on it does not work,the driven unit shaft slides into trans so putting the puller on it does nothing ,also will PB blaster damage seal
firemanjim
Houston Texas
PB is an lube like WD40. The correct puller should have a rod in the center that pushes against the shaft the pulley is on. Post a pic..... It may help with getting help.....
bungee
thanks the shaft that puller goes onto is part of the driven assembly,meaning that shaft that pulley is on comes off also.thats why puller wont work,bad design by Honda they never made a tool to remove this ,Thanks for your help i can not post pictures yet
No bungee, that's what jim was trying to explain.
a puller will push the shaft off the driven pulley.
Need a backing/puller plate for your clutch puller.
Dont heat the seal or put it near it, just heat the sleeve and keep it moving. PB wont do nothing to the seal, hot oil(from the motor) is worse off than that stuff.
fowler
Bullsbrook West Aus
Your puller should pull the clutch off
If the shaft slides out the trans then take it our
Put the whole thing in a vice
Close the vice so the shaft is though it
And the pulley is sitting on top
Close it so it's just loose on the shaft so when u push it it'll slide
Hit the shaft with a large punch and hammer
That should get it out
Otherwise use the puller
Try that first if u have the right puller
