Driven clutch problem question
danielzink
Hey all,
My kid was complaining that her kart didn't have same top end as normal.
I found this:
Does this necessitate a rebuild or can I take the clutch apart and re-orient the wedge onto the buttons ?
Thanks, Dan
Axx3d
MN
You should be able to remove it, dissasemble it, rewind the spring (if not broken) and it should sit sit back on the buttons..
danielzink
I've done a bit of searching.....is there a write up anywhere that anyone knows of for the driven clutch rebuild ?
Thanks, Dan
KartFab
Dallas, TX
They don't need to be rebuilt, just cleaned and dry lubed. There is a sticky in engines and clutches "maintaining your torque converter"
