dcastillo
this sections been dead a fews days so here goes....
Im still planning on getting dual motor independent drive wheels on my cart (as funding comes in
I figure stage one is the wheels then the motors...
been looking all over for a good setup... seems I have a hard time getting things to match nicely (as in sprockets with dual flanges hubs with the right bolt pattern on the rim and then find a tire that fits) been giving myself a headache
finally came across this setup that seems good, although narrower then my current tires that are almost 6" wide.
http://www.northerntool.com/shop/tools/product_200331225_200331225
http://www.bmikarts.com/Sprocket-35-72T-2-1316-Bolt-Circle_p_1377.html
what do you guys think?
what are the pros/cons of going to a 4" tire from 6"?
the only mod I would need to do is chagne the bearings out since I need a 5/8 ID bearing...
On a separate note, is there a crude way to guestimate the power of my motor since Im undervolting it?
its a 2.5HP 90V but im only hitting it with 48V. normal accelerations draw 30-40A and pavement cruising is at 10A???
(Im trying to get an idea of what size motor I need to get the same power output, 800W, 1000W, etc)
thanx
danny
thanx
danny
