Hi,
I'm new around here and need a bit of help. I'm working on side project fun kart which will be powered by a Robin/Subaru 22hp engine. It came from a generator and has a tapered shaft, and I know this topic has been covered a trillion times already. I determined the most economical way to make use of this is to install an additional jackshaft that drives 1:1 engine speed and have the drive unit from a torque converter installed there. (there is a nice flat, round spot on the crank where a thin sprocket can be placed. Minimal machine work, minimal use of adapters and such)
The question I have is about the drive angles of the chain: I've always had the notion the drive chain turning the axle must be installed in front and level with the final drive sprocket, like a motorcycle. Is this right? For example, if the last jackshaft was installed directly over the axle sprocket, it would be driving the wheels "up" rather than "forward". Or does this matter?
Thanks for the help!
