drill rpm?
fowler
Bullsbrook West Aus
what rpm should u run your hole saw at
i run it quite slow but in the vidios iv seen of tube notchers they run them flat out
also what rpm do steel drill bits run at from 6 to 14mm
we had a 10 year old set that were buggered so we bought a new set and id like to use them properly
Cam
Nz Petrolhead
Whangarei, New Zealand
300-350 rpm for drill bits, hole saws a bit slower - im guessing thats what you mean, i mean ive never used a hoe - saw, but hey..?
Just run the small file under the teeth, or if your quick a cutting blade on the grinder, give em a lick so they are sharp and you should be able to use them for thin metal/alu and wood.
Cam
Nz Petrolhead
A grinder is how ive always done it, can get real quick when you do it all the time, the weld fills the gaps if you make it slightly off shape
fowler
Bullsbrook West Aus
i was tracing it out with a perminent marker and cutting it out
i got it down to 1min a cut but the tube nothes are only seconds
fowler
Bullsbrook West Aus
because building a roll cage is slow and i have bad paitiance
the longer it goes on the more inpaitiaent i get and thereby the more miktakes
i admit a personal flaw
a work in 1 hour segpents to achieve a better result
Cam
Nz Petrolhead
Im not really patient in this hot weather in the stuffy shop, so i just tend to have multiple smoko breaks somedays, i do take time in how i do my round tubing though, i cant say the same for square tubing, its ugly as ay.
