Done Felled off the Wagon
VP Karting Oxygenated Race Gasoline
http://www.vpracingfuels.com/page469671.html
T4 (Unleaded - 100 Octane - Oxygenated)
New! T4™
T4 is designed for stock or slightly modified competition karts. Unleaded and ethanol-free, T4 is a direct pour-in replacement for premium pump gas, which has a short storage life and has caused a heightened need for repairs in the karting industry due to its ethanol content. While drivers facing extreme conditions are forced to add octane boosters or race fuel to increase the octane of pump gas, T4’s 100 octane rating (R+M/2) provides greater protection against detonation. Compared with more expensive performance parts that increase power along only a small slice of the power curve, T4 offers 2-3% more power and better throttle response across the entire RPM range.
NOTE: T4 is oxygenated, so if your sanction's fuel rules preclude oxygenation then T4 would not be legal to use. Keep in mind that pump gas is oxygenated (with ethanol) as well though.
VP113 (Leaded - 109 Octane - Oxygenated)
Offering substantial power gains at a competitive price, VP113 is oxygenated to street gas levels. Formulated for naturally aspirated engines with CRs up to approximately 14:1. VP113 makes up to 2% more power than competitive 110 octane fuels, with gains of 3-4% in engine applications with poor or marginal fuel vaporization qualities. Burns cooler, ensuring power is maintained throughout the longest races and harshest conditions. May require a tuning change, including increase in jet size, for optimum performance. Excellent for any karting application where rules permit the use of oxygenated fuels.
---------- Post added at 06:25 PM ---------- Previous post was at 06:14 PM ----------
E85 Might be next? It is cheap. Jetting is probably smaller than Meth, bigger than gas.
http://www.raceone85.com/
Tomorrow I'll try the RC fuel.
I had my bike up at work and was letting the kids in the kitchen ride it around the parking lot.
I warned each of them to be EASY with the throttle. This was with gasoline.
Everyone of them stood it straight up and got tossed off. LOL
My air filter looks like a crushed soda can.
Anyway, I'll see if I can get a noticeable difference on the 1/4 mile time.
Would need to see more than a ONE SECOND improvement to be significant based on the app's margin of error.
I really should have made those wheelie bars.
---------- Post added at 03:03 PM ---------- Previous post was at 02:42 PM ----------
To Recap....
11.1 : 1 Compression Ratio,
32 Degrees BTDC Ignition Timing,
GX390 Carb with NR Racing Zero Degree (2-Piece) Adapter,
0.063" Main Jet,
0.033" Idle Jet,
Stock GX390 E-tube,
AR3910X Spark Plug
Methanol Alky Fuel Mix
20% Nitromethane
8% Synthetic/Castor Oil Blend
Let's see how it goes.
Hoping for better than worst case.
While riding along, something hit the backside of my left thigh. It felt like a BB - gun. I looked for BBQ-Joe, but couldn't see anybody.
I thought the rod snapped and a chunk of the block had punctured my leg.
Also not the case.
Got it into the garage and figured either a rock got lodged in the TC and then shot out and hit me - or it was just a chunk of the belt that hit me. The belt is severely damaged. My leg will be able to be saved.
There are gouges scraped into the inside of the plastic TC cover. This is the first belt I have lost. It didn't break completely, but didn't want to continue to use it.
Belt replaced, Gas drained, Carb Re-Jetted for methanol, Idle Fuel screw backed out like 3.5 turns.
Just need to fill with some methanol and flush the rest of the gas out of the lines and then I'll put a 1/3 tank of Nitro RC fuel and let her rip.
---------- Post added at 05:33 PM ---------- Previous post was at 04:58 PM ----------
Well it starts, it idles, it runs.
I am disappointed.
Must be slower than with the gas. Maybe with more tuning, more timing, and more compression it would pull harder, but as is right meow... It makes less power (according to my butt dyno).
I'll put up some videos , but not a happy camper. I'd like to mess around with the timing, but nobody's got "TIME" for that.
Running straight methanol in our dragster, it takes quite a bit more fuel than running straight gas. And the alky burns slower.
Perhaps you need some forced air injection.... And bigger jets....
It's lean and the timing is too slow.
I was always aware that that I needed to advance the timing more to optimize for alky fuel.
I could have been lean as well. Never tried to tune for alky or Nitromethane before. I was hoping that could make more power than gas with the same timing. I was hoping the jets were big enough.
I have READ that tuning on alky is a little easier cause you can make it very rich (spitting fuel) and not loose too much power. I also read that if it is too lean, it probably won't run at all. This could be wrong. IDK???
I still have a bunch of the RC Nitro Fuel and might try to tune for it later, but "Winter is Coming" and I've got projects I need to attend to. I'm scared to leave this stuff in for too long. As soon as WS Game 1 was over I flushed the system with gasoline. I didn't run the engine on gas yet, but I allowed gas to run through the tank and lines and carb. I pulled the cord to get some gas in the chamber and cylinder.
I'll put the old jets back in and make sure it still runs on gas in a bit.
I had to put the camera down to flip the choke (0:08) and turn the idle speed lower.
https://www.youtube.com/watch?v=xIjGznVKgGU
---------- Post added at 12:42 PM ---------- Previous post was at 11:55 AM ----------
https://www.youtube.com/watch?v=XGrDGCD2Qz0
FreeRunner15
Yeah, nitro RC fuel is 2-stroke fuel, so it has it's own lube blended in.
I've read about someone doing it though. Was it FreeRunner?
For the record I never had a real chance to test the stuff and mine was a 30% nitro blend. Majority of mine went to waste a long long time ago.
But I DO know denatured alcohol[KleanStrip]a 50/50 ethyl/methyl blend] works very well depending on jet sizes even if the pilot jet in the carburetor is stuck open and spewing fuel out the exhaust(my experience during my 58mph speed run. (Yeah.I could've went quicker and faster in that video although it was mixed with gasoline Hence me mentioning running rich in the video and adding the alky. Noone asked and I had no chance to tell until now.).
Added to post: I got the 30% O' Donnels blend at walmarts website for $18 free shipping.
Well at least it ran. I should be happy. Not sure why, without a tune, I excepted some random jets and RC fuel would make it run like a beast. There is probably some potential here, it ran decent on my first jetting attempt while same timing.
