diy centrifugal clutch
r97
Measure twice cut once
Massachusetts, USA
Well I would look extensively into buying one but if you cannot find one, or just really want to make one, you can. Of course to do so you would need a machine shop, and a decent amount of materials. I really don't think its worth your time compared to just hooking up a belt tension clutch.
r_chez_08
Should be in the shop...
Cornwall, UK
IMO, it is more work than it is worth. Without a machine shop I wouldn't even consider it.
You then need to calculate spring tension and the shoe weights etc.
$25 can get you a max torque
