Diesel weed wacker??
NickKlügs
Berkeley, CA
Hi y'all this might sound crazy but I have a few weed eaters lying around and I was wondering if I could make a direct injection diesel. This won't be a traditional diesel but my idea was shaving down the head for more compression and removing the spark plug and putting a homemade injector in. I would make or get a mechanical lever-driven (not sure how to explain it) pump that would go to the injector. The pump would run off of a welded on lobe on the out put shaft and the lobe would make the pump fire or go right before tdc. The injector would be just a bolt with a hole drilled in it and at the end of the bolt would be some sort of misting setup. (I'll figure it out). High pressure metal piping would run from the pump to the injector and a check valve right before the injector (don't want to blow up the pump or lose compression back through the pipe). And that is pretty much it. I don't know how tune the fuel/air ratio but yeah.
Thanks,
Nick
P.s I had a 2 stroke air blower and I was doing a lot of blowing with it and I guess it got pretty hot because when I tried to turn it off it wouldn't and so I disconnected the spark plug wire and it kept running so I eventually just choked it and it quit. But this tells me that I might not need do crazy compression increasing.
machinist@large
West Michigan, 49331
Why?????
Thanks,
Nick
What you referred to in your PS paragraph was caused by carbon buildup in the combustion chamber, probably caused by the engine running rich. This is a different animal than an actual diesel engine. A genuine diesel engine need's to have a compression ratio that is almost double that of a gasoline engine, which greatly compounds the stresses the engine has to endure, and most gasoline engines will fail fairly quickly under the increased strain.
Then there's the issue of fuel delivery. Any pump that can withstand the pressures needed to actually atomize the fuel delivery is most likely going to take more power to run than you'll most likely get out of a converted weed wacker. :oops:
And to do all of this, you're going to need to be a journeyman machinist at the very least, with an extensive background and a really well equipped machine shop at your disposal.....
NickKlügs
Berkeley, CA
Okay
Well I was going to do a sort of proof-of-concept-type of deal but maybe not. Anyway don't glow plug rc engines run off of compression ignition? And aren't they close to a weed eater engine? Instead of direct ignition do you think it would be possible to just leave it carbureted and try to make it run off of compression? Also I knew it wasn't going to be a true diesel but isn't it closely related?
---------- Post added at 02:39 PM ---------- Previous post was at 02:23 PM ----------
Oh and how does the carbon build up make the engine keep running?
Poboy kartman
Senior Moments Member
White Settlement Texas
ANNNNNDDDDD.......RC engines run on nitromethane and weedwackers run off gasoline, neither of which is diesel fuel.....not to mention you'll need to add oil to it....hard to ignite that mix....
Russ2251
AZUSA:Powered by LAWN-BOY
Some decades back I built model airplanes that utilized model diesel mills.
All that is needed is a means of adjusting compression...externally.
I used to mix my own fuel which self ignites if compression is high enough, and fuel mix is correct.
Edit:
Here's a pic.
machinist@large
Actually your idea will work and can be done more simply than what you have described.
But can it be done if all he has by way of tool's is an adjustable wrench, a couple of screw driver's, and maybe a Dremmel tool??? If it takes more than that (as well as any esoteric skills), then it's still not a high school shop project.....
I will give our new OP credit though; he's one of the first we've had in a long while that's listening to the responses we give him, and doing a good job of thinking about it before he asks his next question.
Based on that and the fact you say that it can be done, I'm more than willing to grab the popcorn and watch the show. You never know, I just might learn something myself.....:popcorn: :thumbsup:
NickKlügs
Berkeley, CA
Lol
Uh by way of tools I have a bench grinder, drill press, mig welder, an angle grinder and a full assortment of screw drivers and wrenches and socket set and yes a dremmel :lolgoku:. And a nice outdoor set up :wai::wai:
I have repaired go karts and I have built two mini bike-cafe racers one I made from scratch with a bike fork and wheelbarrow tire and has the famous $99 harbor freight engine and the other one is a converted pit bike with a Lifan 125. Both of them have gone 50. The 125 is faster though:lolgoku: I also have fixed and fiddled around with engines for quite a time and by now I know my way completely through out a Briggs flathead 5hp which I have quite a few of. My original plan was to make the diesel out of one of the Briggs but quickly realized that cast aluminum block would explode. So that's that.
I do realize that this whole thing is pretty pointless other then the fact that I am curious. :cheers2:
---------- Post added at 04:36 PM ---------- Previous post was at 04:31 PM ----------
Oh and having adjustable compression what does that do..?
Russ2251
When adjustment screw is turned clockwise, compression is increased.
Conversely, when turned counterclockwise, compression is decreased.
Edit:
Pic added
NickKlügs
Berkeley, CA
Ahhhhhhhhhhhhhhhhh
I see. That's cool and makes sense.
So how would I do that besides machining a new head? I'm think some sort of way to add compression like the model one and having the adjustment bolt go through the spark plug hole.
NickKlügs
Berkeley, CA
Yeah that's what I was thinking but I don't know once I get home I'll check it out.
Is a diesel still a diesel if it runs on compression ignition but is carbureted? Because that model engine was carbureted so is it still a diesel?
NickKlügs
Berkeley, CA
So I stripped down the engine and just for kicks slid a washer on top of the piston and right before tdc the piston stopped so that tells me there is already no room up there. So I don't think I can do a adjustable compression system unless I get a bolt and thread it through the spark plug hole and then to adjust it I just screw and and screw the bolt. But I don't think that would affect the compression that much. Also I removed the head gasket and that upped the compression a bit. Tomorrow I am going to shave the head a bit and see how it affects it. I just don't know what else I can do to increase the compression.
