crankcase ventilation?
vwmopar
I have a Tecumseh Motorsports h50 witch is actually a h60 bore and stroke. It has a billet rod, dual valve springs, stainless valves, no governor, and a Tillotson hl 334wx carb. From what I have read it will rev close to 7k. Don't know yet haven't ran it. My question is I see all these racing karts and beefed up mini bikes with catch cans or some sort of breather system. Is this necessary? The block has holes drill and taped for it already. These engines were meant for racing go karts. Mine will be in a mini bike. Any help would be much appreciated.
Poboy kartman
Senior Moments Member
White Settlement Texas
It really depends on the engine. ...it couldn't hurt. ....
Most often, crankcase ventilation becomes necessary with higher compression because of increased blow-by.
Some automotive racing engines must actually run a vacuum pump in the crankcase. ....because of high compression and very light piston rings....
Which both are to squeeze out that little bit extra.......
fowler
Bullsbrook West Aus
U would fit a catch can if u want
But a breather will suffice
A catch can is to seperate the oil from the air coining out of the crank case
Sometimes it's a requlatioj thing
So your not dumping oil on the track
Sometime in road cars it's an emmisions thing
To get modified cars over the pits (to get them registered)
So they're not pumping oil vapour into the atmosphere
U do need case ventilation in any engine otherwise u risk building up too much pressure and popping something
Usually it runs to the intake
So any oil is simply burnt off in the combustion chamber
U cab fit a little filter to the vent to stop dust getting into the case
Or run a catch can
Usually u find a barbed fitting and screw it into the block
Them push on a length of hose and run it to am what ever u want
A small inline fuel filter makes for a good crank case vent
anderkart
Surprise Arizona USA
Your engines breather will end up puking some oil at high rpm.
Even If you don't mind the mess, a catch can would be a really good way to help keep that oil off your back tire. That'd suck on a minibike... :thumbsup:
Here's a pic of the breather/catch-can system i had on my methanol Tecumseh engine:
That 10" tall vertical section of hose (exiting the sidecover) helped lower the amount of oil my engine puked, but I still always ended up with a couple ounces of oil in my catch can.
