crank shaft taper
theo
Anyone know what the taper is on some of the industrial engines, is it the same as the sled?
mike75925
thinker and tinkerer
Alto, tx
nice you wanna put sled pulleys on an i/c engine. get you a magnetic angle finder (hf has them) measure the length of the tapers. and a mic for diameter. you will probably have to change the weights/rollers and the spring on the driven due to less power.
theo
I relies the internal changes but I was thinking more on the line of the polaris quad 4 strokes. Polaris diesels might me close to the rpm of a ungoverned Industrial engine.
Kenny_McCormic
Kartless....
Michigan Troll
Sled PTO is typically 30mm with a 10:1 taper. In other words, it starts out as a 30mm straight shaft then for every 10mm of travel down the shaft the OD is reduced 1mm.
Kaptain Krunch
Pro Junk Collector
vermont
Yea good luck finding a sled driver that will fit any industrial engines pto. If your looking for cheap torque converters, i thibk some golf cart cvts will work. IIRC raywelder on here is using a golf cart driven on his 18 twin motorcycle.
