So I inherited a lead gas powered go kart a while ago and my kids hated how loud it was. I picked up this electric kit from amazon and did my best to slap it on (https://www.amazon.com/gp/product/B087RFJT8F/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1). The go kart had some weird chain size that I couldn't figure out so I did the best I could. The kart drives great once it's up to speed but it jutters and stutters at low speeds. You have to give it 1mm of throttle or else it stutters and then once it's up to speed you can gradually give it more throttle. Originally, I thought the motor was bad so I got another one. Then I thought the wiring was too thin so I up sized everything to 14 gauge. The gears are 7 to about 60 but I need to double check that. My wife (half my weight) also has the same problem so it's not that I'm too heavy.
Either way, since I have a second motor, I was pondering getting a second controller and wiring them to use the same throttle (debatable). I could get the motors to share the same chain too.
Does anyone know why it jutters like that? usually, if I'm just stuck, the motor will pause, not stutter. Also, how dumb of an idea is it to make the two motors share the same chain? I know I could get a second set of batteries but that's starting to get REALLY expensive for a fun toy.
