convert a Vertical shaft engine to run horizontally
racerc2000
Longisland NY
ive seen many briggs engines converted. the oil splasher changed and various other lil mods.
my question is. I have a kawasaki 6hp engine. it has a oil pump and oil filter.
anyone know of any resources about these specific engines?
it is a fj180
I only ask this because I have the engine and its not being used. and it is very strong. high torque compared to other 6hp engines.
fuel tank and carb are no brainers. is the oil pump just a matter of moding the pickup?
I also have a 14hp brigs ohv but I see it as too heavy and bulky to be used in a go kart or the likes. but. there is a large performance part backing for this series of engine. due to tractor races.
speedshopmike
the nation's crapital
you'd wanna look into oil drainback mods and the sump's shape and location.
why not just use a right angle gearbox?
if it were me i'd be all over that 14hp briggs instead,
bigger's always better.
racerc2000
Longisland NY
well I guess I could use a RAGB any good leads on a supplier?
the 6hp shouldnt be too difficult but the 14... would take quite a large setup. and its a 1" shaft.
theres quite a bit of parts also which is good. some tractor guys claim to see over 40hp out of these 14hp singles.
http://www.eccarburetors.com/estore/index.php?main_page=index&cPath=227_180_23_198
I got lucky I guess. I was doing some work at a house and the tractor was in the yard.
got it for lunch. so under 10$ he dumped like 400$ into it like 4-5 years ago and it just sat. new bat and cleaned the carb and it runs like new. the rest of the tractor was trash so I got the wiring ,trans and tires
speedshopmike
yep, 1" shaft means ya gotta drop dough on a real cvt.
it's a very common swap, though, to put a "big block" where a 6.5 once lived.
there is a 1" driver available for a comet 30 but i can't vouch the rest of the setup is up to 14hp and based on slippage with mine on less than half that i'd guess no.
here's on place for ragb's i happen to know of.
carting/small engines are all new to me; i'm a car & bike guy, but i'm sure plenty of others here could help with vendor suggestions.
https://www.surpluscenter.com/powerTrans.asp?catname=powerTrans
