mark_obius
- Messages
- 1
- Reaction score
- 0
Hey guys I picked up a Tri-rod with what I believe is a Comet setup on it. This is my first belt style torque converter and I spent a few weeks reading up on its assembly and operation. After that it became very evident that the system had been mickey'd with quite a bit. I'm leaning toward junking it all and replacing with a new system but wanted to see what you guys thought.
The driven is 6" with "3/4 S" stamped on it, has a broken cam button and a unknown color spring. The driven was drilled and 2 bolts inserted into it. I can only speculate that after the cam button broke the driven opened too far allowing the belt to fall too far and get torn up by the rivets so they drilled it and added the 2 bolts to stop that. By doing this they turned the driven into a simple pulley.
I believe the driven was made for a 3/4" symmetrical belt. Due to the fact that both halves are curved and that it is stamped 3/4 S.
The drive is about 5" and has comet industries stamped on it. It has a brass spacer and the fixed face is totally flat.
I believe the drive was made for a 3/4" asymmetrical belt.
I can't really determine what series it is. The belt it came with is 5/8" symmetrical but its totally wrong. Too small for the driven and rubbed flat on one side by the drive. Funny thing when I bought the Tri-rod the seller mentioned it was eating belts. I wonder why... hahaha.
Below are some pictures of the setup. I just bought a 212cc from HF to replace the worn out briggs. Looks like I'll be buying a new comet setup also.
What do you guys think?
Drive front: http://i.imgur.com/RrB0x.jpg
Drive side: http://i.imgur.com/syVI3.jpg
Driven: http://i.imgur.com/dF98P.jpg
Driven cam: http://i.imgur.com/lEG6O.jpg
Driven markings: http://i.imgur.com/kJy6Z.jpg
Whole system: http://i.imgur.com/ZxCRi.jpg
ed.
