Comet belt?
1happydude
Bristol, CT
So I go a new carb, and my tecumseh is running strong. However, my torque converter is running real rough and the belt looks worn out.
The kart barely moves from a stop (tried easing throttle and wide open) but hauls *** once it hits 10mph+.
It is very loose and there are 3 teeth missing out.
I measured the center distance and show 7 3/4" with a 7in driven. The comet chart shows 203593 and that is whats on the kart now. It is very loose and I was wondering if I should go one size smaller?
Link to chart is here https://www.gokartsupply.com/tcbelts.htm
I also need to replace the brass bushing.
1happydude
Bristol, CT
You are right about the cleaning. I stripped off all the parts and will grind off the rust and degrease the gears. I read online to use dry lube.
Here is the slack I have. I already ordered the belt and have half an inch of motor space to take up the slack.
