Comet 20 clutch troubleshoot
joeward87
Hey guys got a manco go kart for my girls two seater with a 7hp Suzuki on it and best I can tell it has a comet 20 clutch.... when going from stopped/low rpm to uphold you have to give it quite a bit of gas before it kinda bangs roughly in and motivates is this going to be a worn belt issue of is the need going to be a upgrade to a 40 series if that's possible.... we live in hilly rough terrain so low end power is more important than top end. I have placed the internal tension spring in the off road position this helped some but still does it.
big-d
Mapleton, Utah
I have a 20 series on a 5hp that came on a yerf dog. It did the same thing. I opened the driven clutch up (the one attached to the engine). The 2 rods on the shoes (weights) were bent and worn pretty bad. This would make it bind internally when trying to engage and would also get stuck in the engaged position, stalling the engine. Replacing the shoes and springs fixed the issue for me.
Also try cleaning it and make sure all moving parts are free to move. There are tutorials on cleaning torque convertors on this site in the FAQ section, you can also find them on you tube.
