Coil Gap on Predator 212 (Stock)
bnomad
Tucson, AZ
Hi All,
I removed the coil on a stock Predator 212 while trying to diagnose issues with a fouled plug/running rich. Most of what I read said to use a business card or a dollar bill folded in half top measure the gap. I would like to use a feeler gauge to get back to square one and eliminate the gap as being part of the issue. Does anyone know the actual gap needed on a Predator 212 Hemi?
Thanks!
bnomad
Tucson, AZ
Hi mckutzy, Thanks for the quick response!
I figured the coil gap was not causing the fouling but wanted to eliminate it. The carb has been replaced and the plug is still fouling (plug has been replace also). The plug is not wet like it was before the carb change, the fouling in now more of a carbon build up. As the engine runs it progressively gets worse. It is most noticeable at idle (missing and dies). If you put the kart up on jacks and run the engine full out for a minute or two, the engine will idle normally. My guess was the plug was not getting enough power from the coil.
Any other suspects I should be looking at?
Re-clean the carb....
Poke out all the holes with a fine guitar string.
Check to see if the insulator plate and all gaskets are not cracked....
What other mods are done....
Pics.... and could you fill out your profile to let us know where you are located.... might be someone nearby to help you....
bnomad
Tucson, AZ
Thanks for your help, I filled in part of the profile, at work right now. The kart is at my parents house (also where our new track is at). I live in the middle of the city, they live outside of town with property. I will get some pics posted then next time we are over there.
The engine is stock as far as I can tell. It was on the kart when we bought it. I bought a new carb off of ebay when we started having issues. It came with a new gasket, the metal plate and plastic spacer looked crack free when I put the new carb on but I will look at them a little closer. One thing slightly different than stock is the new carb has what I believe to be a high speed mix screw. It is a small brass screw that has a spring on it. What I read online is to screw it fully in, then back it out 1-1/2 turns. Does that sound right?
This is the carb I bought:
https://www.amazon.com/gp/product/B01AOXTEUO/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
Poboy kartman
Senior Moments Member
White Settlement Texas
What the 1 1/2- 2 turns means is just a starting point to get the engine running.
While it's running...screw that screw in and it will either speed up or stumble...you may need to open it...the engine will let you know. Actually...the engine will achieve the highest idle while running slightly lean. So you need to give it full throttle from idle...if it's lean it will stumble and take a bit to recover...so you will need to open the mixture screw a bit until gunning it ...it recovers immediately and doesn't stumble.
bnomad
Tucson, AZ
As I back the adjustment screw out at idle the engine speeds up. I will try the test you recommended, applying full throttle then see if it stumbles on recovery.
Sorry for the possible stupid questions. But by turning the adjustment screw out am I increasing the amount of fuel in the mix or air? or what exactly does that screw control air or fuel?
