Clutching
Sportsman850
Minnesota
Hi All!
I'm re-powering a yerf dog spiderbox with a 13hp engine. I want to use a comet 40 cvt. The issue I am having is what size sprockets to use.
Info about the project: The potential load including weight of engine, frame, passangers will be around 1100-1200lbs. Tire size will be 22" in diameter for the rear, I assume the front does not matter. I'm not after major speed but 30-40 mph would be nice. I'm mainly looking for the power to stop on hills and be able to go again. I'm thinking either a 40/41 or a 50 chain.
I plan on running a jackshaft system. So anyone out there good at this gearing stuff?
Thanks much!
Greg
With that weight I would almost think you would want a snowmobile cvt. I know they could handle the abuse.
sled cvts (as all) are also tuneable..
to engage at different speeds.. normally they come with three weights and one spring IIRC..
heavier weights and weaker spring means sooner engagement.
Just check the supplier for a tuned kit.
I think you can get it down to 2000rpmm for fully locked position (which is what the series 40 will have as a default)
Sportsman850
Minnesota
Ok well I bought the 40 series already and am off on the weight. The cart weighs 300lbs or so still running the 22 inch tires, and the passenger load will hit 400lbs so total of 700lbs or so. I guess speed isnt a factor just the power needed to power the cart. Thats the trouble I"m having what do i need for gearing? !3hp predator series 40 clutch, and what gear in the axle and jack shaft. Any help?
OK. You are going to have to gear at least 8:1 IMO. There are numerous sprocket combinations that can be used. The formula is (JS in/clutch)*(axle/JS out). You are going to have to run through some numbers to see what works for you. The clutch tooth count will be your tc sprocket
That's indeed a heavy kart..
with a bit of math you'll find that to run on pavement up a 5° inclination
you already need 273.6 N
given a 13HP predator should provide around 25.7 Nm and the series40 has a 2.43 reduction on the low end..
with tyres that size
you'd still need a gear ratio of 9.63:1 to move up that inclination.
That is if I hadn't made a mistake somewhere of course ;)
Now, it's basically stupid to assume you want to go uphill all day,
And maybe you don't even need to climb that much of an inclination at all.
but I'd still recommend something between 8:1 and 9.5:1
on perfectly levelled surface (pavement) you can get away with 6:1, but that'll eat on your belt plus you cannot even climb a curb..
Sportsman850
Minnesota
So Sid what your saying is loose weight fatboy lol. My 2 kids combined weigh 300lbs. So in the gear ratio is that simply taking a 10 tooth and 90 tooth for example? 90/10=9, 10/10=1 so is that a 9:1 ratio or do you go off of the diameter of the sprocket? I would think diameter i what you would go off of.
the gear ratio indeed is as simple as counting teeth
10T on the TC and 90 on the axle is a 9:1 ratio.
to calculate the forces though I indeed took the sprocket diameter into account.
(rounded to ease the math)
a 60 T #40 sprocket is nearly 10" in diameter
uhm ...
yeah well I haven't adjusted the sprocket diameter according to the toothcount later on.:oops:
I should quit doing mental arithmetics when it comes to things like that :lolgoku:
basically it's engine torque times the low ratio of your TC
as an applied force to the sprocket radius.
and on the other side it's the required force to push the kart
applied to the rear wheel radius
and adjusting the sprocket size acording to the toothcount, that'd be 77T (12.55" dia sprocket)
So 7.7:1 gear ratio should work...
but to be perfectly honest with you, I now confused myself with the math; I need to think about it after a caffeine refill ;)
But I'm rather confident that, just as Paul said, a 8:1 ratio will be just about ideal.
a little 'bonus' in torque is always good to have to ensure the actual clutch can fully engage :D
