Clutch tuning!
Jrgunn5150
Rudderless
My Kart is a Fox (Manco) Vortex, suspension, "yard kart" type.
I have a Predator 212, with the basic "Stage 1" mod's, pipe, intake, jet's.
Running a Comet 30 series to a 9 tooth Jackshaft, 60 tooth sprocket, 16" tire in the rear.
I currently have the driven set in the third hole, for offroad terrain, and my 260 lb butt. I'm wondering if I got that wrong or what, but it feels like I'm getting a nearly immediate shift to high gear. I also really can't spin the tires much, even in dirt. I can induce a drift, but not blow a donut.
On take off, it feels like I have a big bog, then it winds out. I'd like to go up in tire size, but I have my doubts as to whether the lil 212 can pull it.
Here's a video showing the performance with myself and my niece on board. I floored it in front of the Nissan and that's all I got lol.
https://www.youtube.com/watch?v=nZFvvGAT31Q
Jrgunn5150
Rudderless
i will be quick to assume you still have the governor attached. ?
No, no governor, sorry, I left that mod out.
I should also add, that shortly after this the belt disintegrated, and may well have been the wrong belt to begin with. It was certainly getting looser and looser as the day went on, to the point where it had visible play, and seemed like I could just pull it off by hand if I really wanted too.
I think I may have ordered the wrong belt, I didn't measure, I just ordered the same belt number that was already on it.
FreeRunner15
welp, :popcorn:, i guess i'll be learning something new along with ya.
Now to wait for the gurus to step in. :popcorn:
---------- Post added at 11:07 PM ---------- Previous post was at 11:05 PM ----------
..but i'm going to place my bet on the belt size being wrong.
Jrgunn5150
Rudderless
Well the belt seemed to stretch over the course of the day. It started out tight lol, it was 12 bucks, so it may have just been junk lol.
I went back through my purchase history, and Comet 203589A is the correct part number for my kart, unless going from a Subaru to a Predator changed the distance somehow.
For starters, if you paid 12 bucks for the belt, then you got what you paid for....junk. Measure the distance center to center between driven and driver and then check on this chart to see what belt you need. Then order the correct belt. If you are not paying about $30 for a belt you can forget about it lasting
http://www.gokartsupply.com/tcbelts.htm
With a 60/9 = 6.66 gear ratio, i think you are on the limit with 16" tyres. If you want bigger tyres you are going to have to change your gear ratio to something lower. I would maybe get a 72T axle sprocket. This will also give you more low end torque. Your 212 will handle it, you just got to gear lower
For comparison, my 2 seater with 212 ( stage 1 mods ), 30 series TC, 16"tires, and 6:1 gearing went from 0-30 mph in 10 seconds. It topped out just shy of 40mph in my normal stretch of straight away (3/8 mile?). When I changed from 6:1 to 7.5:1 (60T : 8T), my 0-30mph time MAY have improved 1 second, top speed was reduced to 36/37 mph, and it handled (what I call medium) hills without issue, when it struggled slightly before.
I have not adjusted any TC springs or settings yet.
I don't have many hrs actually riding either one yet either, maybe 4-5 hrs with each gearing setup. ALL riding has been done with original belt that came with knock off TC.
---------- Post added at 04:54 AM ---------- Previous post was at 04:41 AM ----------
https://www.youtube.com/watch?v=t7Y3yLnUJz4
This is 6:1 with 360lb of combined passenger weight. Neither Acceleration nor climbing ability( in the snow with balding tires AND driver) was very impressive
Jrgunn5150
Rudderless
Well, I have a 6" driven, and a 6 5/8 center to center distance, which still means I had the correct part number. Perhaps the belt was junk, I'd expect even junk to last a few hours though lol. It probably had 3 hrs of riding on it.
I have ordered a 72 tooth pinion as well, so I hope that helps. Of course they don't make it for my stupid hex axle, so I'll have to figure it out when it gets here.
I wonder if I have my driven tension too tight, I'll get a pic here shortly.
Could the bog be caused by too lean pilot jet?
If it were me, and I hadn't tried to open up the Pilot Jet 1 or 2 sizes... I might try that.
I haven't removed it yet, but think it is under the idle speed adjustment screw (so that needs to be backed all the way out).
Jrgunn5150
Rudderless
I haven't messed with the Pilot yet, maybe I should.
Also, but you probably know from my thread, I've been looking into the blue garter springs for the drive pulley on the TC. 3100 RPM lock up.
Seems to make sense that raising engagement RPM could avoid said bog??? But this is probably just a band aid and may lower Torque at the wheels at engagement. Not too mention shorten time in low gear.
Jrgunn5150
Rudderless
I think you're right, I'm going to try the yellow spring first, I definitely want to increase time in low gear. I also need to verify I actually put the green spring in the third hole and not the first lol. :eek:
