Clutch ratios
BirdFanatic
Jonesboro Arkansas
Hello I seen in a different topic about clutches being burned up.It got me wondering with what my clutch is and what it cost's to buy a clutch like this.Can my 14 tooth Noram Mini Cup Racing Go Kart Clutch, 1" Bore 14t withstand low gear ratios of 2.5 to 1 or even lower is there a limit?
I do not think it is meant for that gear ratio to be honest..
you are geared too high if you ask me...
And no, you cannot gear any higher than that
(higher gearing means LOWER numbers.. I know odd, but that's how it goes)
And there's always a limit.
think about it this way:
a centrifugal clutch will engage at a certain rpm (let's just say 1800-2000 rpm)
the gear ratio is fixed, so as soon as the clutch WANTS to engage it tries to force the wheel into that gear ratio defined rotation (for 3:1 that'd be 600 rpm)
600 wheel rpm means the kart has to go 27mph within a fraction of a second (speed for 15" wheels)
that is impossible (laws of physics ;))
so the clutch will not be able to fully engage and only a fraction is converted to chain movement (that part that your kart-weight-wheel combo allows) the rest is slip and that means heat.
And heat will affect the clutch. as soon as your shoes turn blue they will not be able to provide enough friction anymore.. and then bad goes to worse.
you have a quite powerful engine, and that helps (well as long as the clutch can withstand the power)
the kart isn't able to go faster than 90mph I'd say... gearing higher is pure BS!
(you cannot reach that speed.. all you do is loose torque)
assuming 440 lbs (200kg) and 15" wheels you should gear it 4:1 or lower
5:1 if your clutch engages at 1800-2000 rpm and you want to keep it cool ;)
BirdFanatic
Jonesboro Arkansas
I have 15/7.0 by 8.0 tire I think is what the last number was.I also cleaned off the sprocket on the axle and seen the number 59 i found 3 more 2 piece 59 tooth 35 chain sprockets as well as a 56 tooth 2 piece 35 chain sprocket and a 55 tooth
your wheels are:
15" diameter.. 7" wide on 8" rim
59 is good that (with a 14T clutch) is a 4.21:1 ratio...
I guess it's a bit rough on your clutch so you should keep an eye on the clutch before and after each ride.
56 and 55 are a bit of a stretch and might be used for tracks with long straights and not too narrow turns,
(they WILL already abuse the clutch) but on a raceday it's okay to ruin a 200$ clutch for a win ;)
for fun (not racing) I'd get a 66 T split sprocket to gear 4.7:1,
that's a ton of torque, the clutch will stay most likely cool (440 lbs kart+driver estimated) and it still maxed out at 75mph which should be enough to potentially be dangerous ;)
BirdFanatic
Jonesboro Arkansas
id say kart weighs 380 390 pounds about 3 of my sister i'm 175 funny thing is is i'm 6'1 and i barely fit the guy i bought it from was 6'4. i have 59 tooth on sprocket 14 on clutch.I believe the red springs engage at 1850 rpm with 32 to 39hp most if not all mods done inside the engine and your saying it only maxes out at 75 lol
your wheels are:
No I said
"I'd gear it for a max of 75mph to keep the clutch cool"
big difference.
and with a total weight of 570 lbs I'd gear even lower... 5.36:1 (75T axle sprocket)
to do that.
IMO I would also try aim for 5-6:1 gear ratio. You are not racing this thing, so why put strain on the clutch if you don't have to. Those clutches are dang expensive
