Clutch Peerless 700
buddyochoa
Not Senior Yet
Thorn Hill, TN
What kind of clutch would be the best for a peerless 700? I'd like to still be able to run through the gears, and I will have a 18-20hp engine. I'm assuming none of these have clutches internally.
You should be able to use pretty much any clutch you like, but you should probably avoid "running thru the gears". These trannies aren't exactly synchromesh. The gears are indexed for the shift keys every 90*.
I'n not aware of much use in the karting world, but they've been pretty popular amongst lawn tractor racers. I am building such a racer, and have been researching my butt off. I have a Peerless 700 (and an 800), and since I tore it open, I can quite honestly tell you that these are NOT well-suited for shifting-on-the-fly. While it may tolerate it for a bit, those shift keys will get crucified.
ML-TOYS
long island, new york
Ok so i gotta ask, what is the purpose of using the gearbox if they cant be shifted. I plan on using my 700 on my kart because it has reverse
r97
Measure twice cut once
Massachusetts, USA
They can be shifted, you just need to come to a complete stop before shifting. Having a gearbox like this wont significantly increase your top speed, because your highest ratio still has to be able to take off from a standstill. That said you can incorporate reverse and crawling speeds.
Yes. And the point is, these gearboxes were designed for lawn tractors and other low-speed implements. The original equipment was geared so low, you could take off in 5th gear. Tractors are not like cars in that you start in 1st and work your way up. You simply select your desired gear ratio and go.
There's no synchro rings of sorts in there. One could maybe bevel the keyways in the gears, but I seriously doubt they'd last long. It's be an interesting experiment, though. Worth noting- the gears are sintered instead of machined.
r97
Massachusetts, USA
Just out of curiosity... Why is it that all the lawn mower guys use these things? Are they simply there to act as a RAGB and maybe a diff? Or do people like to have them for the ease of chaining ratios for different tracks? I should think that the use of a standard RAGB and a selection of different sprocket sizes would be lighter/cheaper/stronger.
Some classes require a shiftable mower tranny/transaxle, including the class (modified) that I am building for. Higher classes (supermodified, pro, outlaw, etc) allow an RAGB or even a horizontal engine and no gearbox. It's simply a matter of how stock-ish it has to be. And yes- if I understand it, some guys gear the tranny to allow for different tracks without regearing.
B.M.800
TheBeal.
Central PA
If I can get one cheap, Id be willing to try it...
:idea2:
Nah- A hydro sourced from a lawn tractor runs too slowly, and overfeeding them will result in hot oil baths for everybody.
However- a DIY hydro could work- a pump on the engine, a motor feeding the axle, a reservoir and some valving. It's entirely doable, but there is a loss of efficiency. I would like to see it done, just because. I have most of the parts to try this- but too much other stuff to do...
B.M.800
TheBeal.
Central PA
Well tell ya what Toystory, next year when I go camping up there... Ill take what you got, we could meed around Sudbury or Perry sound?
:roflol:
{EDIT} And I was thinking, using a transaxle, the gear ratios... too close together?
Trying to go faster, a person still may no have a decent lowend, likewise, a low gearing you wouldnt have much speed anyways...
Although, I have a set of half decent 31in tires I want to stick on a mower transaxle...
What do you spose is the best way? Just a hub withe 5bolt pattern with a key way in it?
