clutch help please.
tonks79
herts uk
Hi i have a gx160 and today i took the clutch off as it was engaging to quick so thought i'd have alook inside anyway got clutch off but i cant seem to get the hub off to ook inside i took the c clip off but still wont open p.Any hlp would be great.Thanks.Its a centrifugal clutch.
tonks79
herts uk
Cheers for reply on the side it says north america clutch i tried penetrating oil it comes out a little bit but thats it and dont really wanna stick screwdriver as will bend it.Any other ideas pal?
tonks79
herts uk
Will do as soon as phone has charged a little so if u don mind just keeping an eye on my post would be real grateful pal.
tonks79
herts uk
Thanks for link pal.
Well checked out link but no info on how to get the clutch apart like i said in earlier post i take off one c clip and it moves a little butt does'nt come apart.Hope someone can help please.Also just found out its a noram clutch.
anderkart
Surprise Arizona USA
Your clutch looks like its prolly one of Norams older models (does it have any model # info you could tell us?)
This link:--> http://www.smallengineperformance.com.au/index.php?option=com_content&view=article&id=1&Itemid=29 and the video below might give you some helpful clues, but I dont think any of these Noram/Premier clutches are your exact model:
http://www.youtube.com/watch?v=cg-eG-2cEyg
I agree that we need some model number if you have it. Have you got some better pics of your clutch?
Are there any set screws that you have missed? What you can maybe do is take some fine sandpaper and sand the end of your shaft slightly. Your clutch might be getting hooked up on some sort of ridge or rusty bit. You might not see it, but it could be there.
tonks79
herts uk
I will get it off again at weekend due to work but there are no more screws or nothing holding it also all that is written on clutch is "North America Milwaukee".There is nothing else.It moves slightly when c clip is off say quarter inch or so.Thanks for all your help and replies very grateful.
Like I said, see if you can sand the shaft slightly to see if it slips off. You can also use a gear puller to get it off
tonks79
herts uk
Sorry it took so long heres the pic of the clutch.
Still cant get it apart,tried everything. Hope some1 can help.Thanks.
souperman000
Westlake Village, CA
have you unscrewed the bolt holding the clutch on the shaft? See as it is in the picture I am not sure if you have or this is just an old pic.
Try a puller with lots of WD-40, Pb blaster etc.
tonks79
herts uk
Hi I can get the clutch off the kart without problem but its getting the clutch apart that I'm having trouble with,I take the c clip off and it moves a little but can't get it apart. There are no other screws or anything holding it together. Hope someone can help. Thanks.
tonks79
herts uk
Sorry pal not that clued up, what are burrs? So when I reove the clutch were the c clip is,is that were I'm looking?
