Clutch for Predator 670cc?
ironbutt
Pacific Northwest
OK, so I'm going to install the Predator 670cc engine in my 82 Honda Sabre roller.
I'm working on a shaft to chain conversion using the bevel drive differential pulled from the original (dead) 750cc V4 engine.
I'll connect the final drive sprocket to the new engine via a jack shaft.
But, what is the best way to get from the 670cc PTO to the jack shaft?
Is there a centrifugal clutch w/ sprocket that can take the high HP and RPMs of the 670cc?
I know that the buggy and golf cart folks like the Comet 780 but it would need a secondary pully mounted on the on the jack shaft and the two together are pretty expensive.
Any ideas for a cheaper but tough clutch?
:cheers2:
---------- Post added at 02:23 PM ---------- Previous post was at 02:18 PM ----------
How about this one?
http://www.vegascarts.com/product-p/gkc14-1.htm
It says that it will go up to 30HP and 7,000RPM.
Randy H
I had a 82 V45 Sabre in 83, had to sell it on account a being a baby daddy.
I'd call VC if I were you. Or join the forum at bigblockcarts.com those guys have a lot of experience with twins. And newbie friendly.
I just picked up 780 driven for $100 on eBay. Searching for a drive. I'll probably bite the bullet and go for VC's $250 drive. Although adapters are available to use a snowmobile 780. It requires cutting your shaft. Owee, I don't want do do that.
