Clutch facing materials
krakkah
Hello, my first post! yay?
Umm so...
I am looking to make my own clutch for a small buggy and looking into cheap and easy facing materials that i can put together myself. Im kind of hoping there is no need to seek out a professional workshop to have such a thing made, it really is a super cheap build.
The clutch itself will either be a multiplate or single plate, using springs for clamp force and lever activated. Centrifugal will not do.
Ive considered, wood, leather, fibreglass, woven aramid, carbon fibre, even lino.
does anyone recommend a heat resistant epoxy suitable for clutch linings?
I know enough about clutches to know there are many factors surrounding a clutch design, but so much is governed by the facings you choose.
is there somewhere that sells clutch facings as a sheet that i can rivet?
I'm in Sydney Australia.
Cheers
:auto:
Hello and welcome,
What is the intended HP and what is the motor to be used?
Alot of automotive clutches have semi metallic grab elements.
I'm assuming you have a machine shop available, or at least a lathe to use? Can't really build much with out at least a lathe, in this manner that is?
Have you consulted a brake shop that relines brakes and clutches?
krakkah
Hello mckutzy, thanks for the reply.
I have a fairly well kitted out workshop with lathe, mill, mig, tig, grinders, drill press, and aluminium metal casting foundry. Ive been making stuff for 10 years or so as a hobby.
This project is a small kart using a 62cc chainsaw engine, 4hp at 12,000rpm or around abouts. For a child no less and I'm just playing around with the gearbox ive made. Forwards and reverse is all thats needed. The chainsaws existing centrifugal clutch has been ditched as its a pain in the *** design.
The diameter of the clutch im guessing would be about 100mm OD and 50mm ID with a face area of 5890mm²
I might just try a brake place, I had no idea they could reline such things.
But really, fibreglass or carbon fibre sheet should do the trick and just replace them as they wear? Just trying to avoid the smoke and constant attention fixing it lol
well...
if you want to build a disc clutch why not get the discs off a shelf?
It's easier to maintain (since you will need to renew the linings every now and then)
and in the end it will be cheaper too.
So, build your cage for a std size clutch disc;
like a common motorcycle, a matching car engine well you know..
since IDK what size of engine we're talking about, I cannot recommend anything but:
see what's on ebay.. find a set like this:
http://www.ebay.com/itm/Tusk-Clutch...s&fits=Make:Honda&hash=item43bd64f0a4&vxp=mtr
that matches your needs... and call it a day ;)
[EDIT]
Oh.. you replied while I was typing...
62cc chainsaw engine... okay, maybe a 50cc scooter clutch, a 125cc motorcycle....
or.. why not use a -forgive me- chainsaw clutch and modify the centrifugal to a lever actuation?
Logan County Ohio
Something an old timer told me a long time ago. "Clutch facing material is meant to operate "locked up", in other words "not slip". Brake facing material is meant to operate while slipping." The two should not be interchanged even though they may look so similar.
From one of the best old crane operators I ever laid eyes on.
krakkah
itsid thanks for your reply.
I guess im trying to aim this thread purely at the topic of "if one wanted to make a clutch from scratch with linings off the shelf or something homemade what would or could the result be" even it means slightly more complication. Being complicated is not something im worried about. But a freely available substance to deal with heat and maintain a constant coefficiant of friction could be out there known by someone.
I think I will try a few different things and see what happens. A multiplate with woven arramid cloth and resin might do the job.
Cheers
jeeperjoel
san bernardino co., CA
may not be the answer you're looking for, but what about machining a shaft adaptor to accept a CC with 3/4" keyed shaft? then it'd be an off the shelf replacement, plus already designed for a cart/minibike application? oh ok centrifugal won't do, missed that, sorry... but with an adaptor you could run a comet TC...
