Clutch bolt coming loose
NO.. don't use red locktite on the shaft bolt.. That will be more or less permanent... And he won't have any choice to cut off the clutch....if he needs to remove it...
OPmini
moo
Phoenix, Arizona, United States
YES USE THE RED LOCTITE!! lol yeah, it's pretty hard to take off when the bolt is cold, the key is heat up the bolt with a soldering iron and then remove it, or just warm up your engine to 500+ degrees Farenheit. I always use Loctite red on stuff I don't plan to take off for a long time, and I know that will get extremely hot. (like a clutch)
