clone question
ddlyspdr
ok i adjusted the throttle stop for wide open throttle to have more speed and power. if i back it out all the way, is that 3600 rpm like the manual says it is or is that way higher? is the factory setting 3600??
slideways
You wont see much rpm gain there.. maybe 3700-3900.. the governor will still hit hard. Only way to get more would be to play with the springs and tabs on the governor arm once you determine how it works by activating it by eye..
Or just pull it completely.. though i didnt notice any difference in power doing it on my motor... the dyno didnt either. Best bang for the buck is an intake adapter/filter and a header. Drill the jet to #36 and hang on.
ddlyspdr
i just noticed that i unscrewed it and it let the throttle open farther and it would rev higher than what it was preset at. i plan on doing a gov removal, valve springs, slight port work, filter adapter and header during the winter, maybe a cam too. but im also going to make a new frame too.
