clone problems
jetlag
Memphis, TN
My friend has a 09' Blue clone in his kart.
It has the governor removed and a header.
Sometimes it has trouble starting/idling. As long as he has the gas wide open, it runs like normal. But as soon as he takes his foot off the gas and slows down, it will start to stutter, hunt for idle, then die. We've adjust the idle back and forth but that doesn't help.
I opened up the carb and checked it, clean. Spark plug was clean.
Sometimes it starts up fine, he can drive around for awhile and then it will randomly die. If he tries to start it again, it won't. We took a break after riding and it died, maybe 10 minutes. It started right up.
Any suggestions? Ideas? Advice?
freakboy
the names 'mater
hick town
All you have to do is to tear the crap out of the plastic caps on the needles so they come off and then your good to go.
jetlag
Memphis, TN
It starts up fine, can run for hours. But then it will just die unexpectedly and if we try to start it again, it won't idle then.
freakboy
the names 'mater
hick town
Tear down clean it all up check all gaskets do a carb rebuild and you should be good to go.
jetlag
Memphis, TN
If it was something gunked up, or dirty, I'm sure the problem would happen all of the time.
The motor can go days without problem, or only minutes. That's why I said it was random.
skid20
Universal Remonster
St. Louis
check and make sure there is no small debris stuck in the carb jet or the emulsion tube.... the smallest piece of crap can get stuck in those little holes and not always block the way, but get stirred up on occasion and keep the fuel from flowing.
also empty your gas tank and add a fuel filter...
I had this same problem not long ago and cleaning the fuel system and adding a filter solved the problem.
