clone choke problem help!!!
DCC!
hawaii
hey guys its been a while but i got a problem with my enegine now:huh:
ok my clone only runs with the choke on and doesnt run long at that. idk what it could be bc i have already clean the carb and i have good spark and everything else. it just randomly needed the choke to run
can you guys help me??
anderkart
Surprise Arizona USA
See if the carbs base gasket or intake-insulator is leaking (sucking air) somewhere. Spray some carb cleaner around this whole area with the engine running. If theres any leaks, it'll draw the spray in and you'll notice a sudden change in the engines rpm.
1992suburban
I wanna go FAST!!
Sanford, NC
is the carb leakin gas anywhere??
if the carb is clean and you put everything back together right (no air leaks and the the ETUBE JET ect ect. is clean and installed correctly.. )
it should be ok..
let us know how it turns out from Anders advice
mike75925
thinker and tinkerer
Alto, tx
i had this problem once or twice. it was my lash. i set it to agk and hf's specs. for some reason, mine has to be looser to run.
