cleaning flywheel rust
ML-TOYS
long island, new york
ok cool, so i wont damage it with the wheel ?
that was one of my concerns, wrecking it. should i do the whatcha call it, the magneto spark thing too
I would use a hand wire brush for the coil pack area, you dont want to damage the insulation, the laminations are ok just go easy on it.
A wire wheel will get the large, flakey rust & some of the minor rust off but, the best way to thoroughly clean it is sandblasting... after you cover the magnet
okenadie
Columbus, ohio, originaly from Penna
I've had to clean so many of those things it's nuts. Has anyone ever tried to have one power coated. I know that you would either have to keep the coating off the magnet. Or clean it off after. But I'm thinking it might work.
Powder coaters use special heat resistant tape to cover any parts that you don't want coated so, that covers that problem. However, they will more than likely want to acid dip it to clean it; that & the heating process may have a slight affect on the magnet...
Can anyone confirm or contradict that?
I have always wondered.....how do you get all the metal dust /shavings off the magnets. Wiping them just moves the stuff around the magnet
There's a trick to it & I'm not tellin' :D
jamyers
Buffalo Gap, TX
I just wipe all the crud off the side of the magnet onto the non-magnetic part, then away. :shrug:
okenadie
flywheel cleaning
Getting paint on the magnet won't hurt it. But you need to clean it off. Because although the paint is not very thick. It could affect the air gap between the magnet and the magneto. This could cause it to have poor spark. Or no spark at all.
jamyers
Buffalo Gap, TX
I'd think you could clean the flywheel, then set the air gap, then paint it and be fine. AFAIK, the air gap doesn't need actual air in the gap, rather its just the best distance between the magnet and coil for inducing electrical current.
Then again, I've never painted one - rust being a non-issue around here... :wai:
