Choke and Throttle Problem-Briggs 6hp
scat daddy
Thanks for helping out. I put a Briggs Intek 6hp model # 110432 0121 E1 that came off a pressure washer on a kart. The carb idles fine while choked but stalls out when you open the choke. I can open up the throttle while it's choked but do not get any response, just seems to be starving. Getting plenty of gas and good spark. Before this engine was running fine at half choke.
THE HUNTER
"Ghetto Rigging Expert"
Detroit Metro Area
if the carb is adjustable, try opening the main needle valve up to make it run richer.
if not, you prob need to clean it out really good.
Affair_driven
BULL DETECTOR
Wolf Point, Montana
Never mind pic.
I know what carb it is and is an emissions carb. Not adjustable.
Probably clogged jets or faulty float/needle.
Needs to be disassembled and thoroughly cleaned.
Engine should never remain choked to keep it running.
AlphaRunner85
Hendersonville NC
I have had a similar problem with a 5hp briggs funpower with a
diaphragm carb. i have tried the needle valve and i loosened
it as far as is effective and it still dies a with on choke. Ill chek the float but im pretty sure i cleaned it already
