cheap gaskets
Bluethunder3320
well its pretty simple and stupid, but ill still take the time to write it out.
ever notice that cereal box's are made from similar material to gaskets? :roflol:
so why not? free, and basically unlimited supply unless you stop eating cereal!
EDIT: or waffles!!
trace the old
hole punch
done
installed
Cam
Nz Petrolhead
Whangarei, New Zealand
rusty has a point, maybe you should add in your description what these replacement gaskets are suitable for, do they work well?
sideways
Unfinished projects king.
Perth, Western Australia
Brendonv made a video of this ages ago, here's his thread.
Now, the thickness of the gasket that goes at the bottom of the cylinder on a 2 stroke is very important, they change the height that the ports are, thicker (or stacked) gaskets will push the ports higher thus(generally) moving the power band higher in the RPM range (and lowering your compression), you may get more power too. Nice, cheap, easy, reversible way to alter your power band. Your gasket looks thinner than the original, so I just thought I would say. :thumbsup:
You can also get a bunch a spent riffle shells of all sizes. They make great hole punches.
Brilliant idea! I think I will do that!
Thanks
Hayden
Nothing wrong with making your own gaskets! Just be sure that you're using a suitable material for the task, and in some cases, the thickness. A good example here is the side cover gasket on a Honda or clone. Gasket thickness will affect crankshaft endplay.
