well, don't make no mistakes..
it's very likely that an electric kart doesn't need any amperage close to 350 Amps..
(well yes.. technically it's possible to go well beyond that limit.. but occasions are RARE
There's a HUGE difference in RC motors and kart motors (or precisely any EV motor [electric vehicle])
And the main difference is this:
RC motors are rated at there maximum powerdraw, as you might know, some even at there very limits (at amps they can burn out in a few seconds without active cooling)
So a 5000 Watt RC motor for example isn't as hard to find at all...
Now, EV motors are rated at power OUT, the power they convert into kinetic energy,
and not even at their limits.. but instead at a rating that's safe to apply nearly all day.
So their rating is MUCH lower.. and in fact they're powerdraw is too...
a 100W 36V motor for example (quite common size) draws no more than 40 Amps max.
Only if you go into the realms of golf cart motors, or anything way above 10000 Watts, you have a good chance of getting much higher amperage and voltage, otherwise only one of the two will rise...
(depends on your choice)
Generally, you will want to keep the amperage low on an EV..
since you can survive nearly any voltage, but touching high Amps will surely blow your hat
that being said.. there is no such thing as a "stepping" controller for an EV really.
and the reason is simple..
it's much more comfortable (easier to use, control AND BUILD) to have a common mosfet control..
full power, just for fractions of a second at a time.. that way.. the motor is simply "off" for most of your riding time, not drawing any power from the batteries
and the only thing you contol is the intervall.
Much like modern day rc controllers work,
and the good news... within the overall power we're talking about an EV controller can be had even cheaper than a quality RC controller.. at least it's not more expensive than that
So, check twice what motor you want (see the
essentials thread to get an idea of the power you want/need)
And then check to see what controller there is.. kelly controllers are cheap, and of good quality for example...
