Cheap Clone Motor Fix For Murrays With TAV 30 s
GoKartEnthusiest
Hello to you all DIY ers!
I bought a Murray Go Kart a couple of months ago with a bad motor, I own 4 Karts currently, and kind of new the Go Kart world. My smaller black one had a bad motor also, which I replaced with the ever so popular cheap Predator motor from Harbor Freight. It is really fast, and the motor is reliable. I since got the idea to impose the same motor on my Murray, which was an issue considering the TAV converter from comet does not have enough clearance to mount on a angled cylinder engine such as the predator motor has. Doing a mach up, I noticed I needed about a 4 inch lift on the motor to make it work. If anyone is like me, I wanted the cheapest easiest alternative to mount the motor higher and not have to make changes to the chain, brackets, ect. I decided to go my local machine shop to see the options. I ended up buying a piece of 2X4 box steel that is 7 and 1/2 inches long. I had them cut the piece off, took it home and drilled holes to mount the engine too. This saves time, money, and materials, as well as keeps the original mounting holes to slide the engine forward and backward to adjust things.
You might also notice from the pictures that I mounted a seat off a Lawn Mower that has arm rests, as well as the springs underneath. It is a way better comfortable ride.
Anyways just thought I would share my project with everyone that is looking for a cheap way to install a honda clone motor on their Murray and not have to do much fabrication at all to do so.
Hope this helps!
GoKartEnthusiest
Thanks for the welcome :)
I unfortunatly haven't been able to ride it with the new set up yet, my kids roasted the belt off it when it did run, the belt is on order as well as some new brake pads, been needing those for awhile, I am waiting for all the to come in and be installed before I take it on its maiden voyage lol. I am a stickler on having everything working correctlt, I ordered all that this morning so hopefully by the weekend it will be up and running, I had to order a drive pulley for my manco go kart as well, it has a jackshaft setup with a brand new honda clone as well, so very excited about riding both of them as I have never riden them, as they had issues when I bought them that had to be rectified.
GoKartEnthusiest
Ok,
So I recieved my new belt that I order by Murray part number 37X98, as indicated on my part diagram that I found online for my machine, after noticing the belt was absolutly too long without even taking it home, I started looking online.
The cover on the TAV 2 system says its a Asymmetric 30 Series comet converter. As it did not come with a belt I am having a hard time getting a belt that will work. I ordered a belt before that I thought was the same, and the machine tore the belt up in about an hour, which was obviously the wrong one, and using the Murray part number is not worth a crap either apperantly.
Going by the chart listed at with a 6" Driven Pully
http://www.gokartsupply.com/tcbelts.htm#30SERIES
I see that the Murray part number toward the bottom
Comet Belt #203597A is also known as Murray Belt Number 37 X 98
203598A
BELT 203598A
11 11/16 to 11 3/4
10 15/16 to 11
37-7/64
Now my setup is no way 11 inches apart, its more around 7 inches, so I am looking at the one at the top
Part Number
Description
Center Distance
Belt Marked
Price
Add to Shopping Cart
6" Driven
7" Driven
12-8487
BELT 203589A
6-15/16 to 7
No Fit
27.0
The thing that concerns me is the "No Fit", can anyone give me some advice on which belt I need as I am a little frustrated over this.\
I too am confused by this. The aluminum back plate leads me to think it's a Comet TAV2, which uses 203589. Hover- the TAV 2 uses a 6" driven, not a 7". I can't help but wonder if you got some sort of frankenstein that somebody bodged together. I strongly suggest you send a PM to Blazkowiez; this really is his department. He deals with CVTs on a professional level and is most likely to be able to sort you out.
GoKartEnthusiest
Checked out your website, why cant you be in Tennessee lol
Thank you for the answer Blazkowiez, I do believe 203589 was the original belt number that came with the kart. I bought it from a 18 year old kid that did not do regular maintenance on the kart, which is why everything on it needed to be fixed. I did receive a belt for the kart when I originally purchased it, but was 3-4 months ago, and my kids wasted the belt riding it, and I was cautious about the original belt, as I am sure the kid didn't realize it had to be the same belt, and it didn't seem like the kart every had much torque to it, which I am positive the converter needs to be cleaned (have watched the video on this). I just want everything to be right as toystory pointed out it is a Comet Tav2 with a 6 inch driven I took a pic of the original cover as well. Anyways I will be calling you later this afternoon to get some parts I need
