Champion Spark Plug Fail
jamyers
Buffalo Gap, TX
Twice now in the last 3 months this has happened to my recently-rebuilt (less than 20 hours ago) Kohler 14hp vertical shaft single-cylinder engine on a John Deere lawn tractor.
After it sat for a couple of weeks, it wouldn't start & run unless severely choked, and then it'd run rough, and eventually not start at all; making me think that the fuel has gone bad and/or dirt in the carb.
After pulling/cleaning the carb and not finding anything particularly wrong, I checked the spark with an inline test light. Both times the test light shows a weak spark, but still a spark. Pull and inspect the plug and it looks just fine, other than being wet with fuel from choking.
Replace the spark plug with a new one, and it starts and runs perfectly. I scraped the electrodes of the old plug clean just to be sure, put it back in, no start. Install the new plug, and it runs like a champ.
The first time around, the plug had been in there since the rebuild, but the last plug didn't have 2 or maybe 3 hours total on it. Champion RC12YC both times.
Anybody else having issues with Champion plugs? Any ideas why plugs would fail like this?
In 35 years of messing with engines, I've never had a plug fail, let alone 2 - grrrrr.....
95badbird
Srping TX
champoin is in my opinion, the worst you can use.
they are cheap.
see if that plug crosses over to a NGK or something/anything other than a champion.
carter
I've never had a problem with champion plugs. When my 21HP vert shaft(dual cylinder) was having problems, a mouse had actually eaten through most of a part of the wire coming from the coil and lodged itself right next to the starter.
FatCat
2 stroke Addict!
Ottawa, IL
Id start looking at the ignition system. One plug being a dud I can believe but not two. Something in your ignition is what's damaging the plugs. is the porcelin broken on the plug? If so detonation? Sometimes the shock from detonation will crack the insulator on the plug. You may have fouled these from running with constant choke also. I don't believe your problem is the spark plug.
That may be... On the other hand, I have seen plug go bad in short order, even a bad one right out of the package.
Being a cheapskate, I have use probably more Champion plug than other brands, and I cannot say they have been abnormally bad to me, as compared with the other plugs than I have used. Either (like FatCat says) you have a contributing problem, or wicked luck.
Kaptain Krunch
Pro Junk Collector
vermont
I have had bad luck with champion. but i agree with everyone else, sounds like you may have an underlying problem.
jamyers
Buffalo Gap, TX
I was also thinking something's going on somewhere else in the ignition, so this afternoon I pulled the tin off the engine to get at the coil & wiring.
The coil checks out with a multimeter, no opens or shorts and proper resistance. The plug wire from the coil looks good with no visible injuries to the insulation. The only other wire is the "kill" wire, and it looks good as well. Air gap is set to spec as well. The flywheel key is intact, so the timing isn't off.
I don't think it's detonating, at least I can't hear any and none of the other engines around here are having issues with the same fuel.
I've looked the latest bad plug over closely, and can't see any traces of a crack in the porcelain...only thing I haven't done is put my ohm meter on it and check resistance / continuity from end-to-end; any ideas what it should be on a resistor plug?
[EDIT: Just checked, got Infinite resistance / Zero continuity along the plug.]
I'm thinking that Champion isn't what it used to be...
crazyman
Yorkville Il
When I was a kid, my 5hp briggs would foul a champion every other week. I put in the cross referenced NGK and never had any fouling issues after that. To this day, I still prefer NGK.
Russ2251
AZUSA:Powered by LAWN-BOY
My 2¢...
I never had a catastrophic engine failure until I switched to an NGK plug.
Internal seal broke and dropped center electrode into combustion chamber.
Might have been a freak thing but was enough to convince me to stick with Champion.
Dump the resistor plug.
My 2¢...
Ooh... Betcha that was ugly!
