Just do yourself a favour if you're going to build a wooden kart- I'm not completely against it, but you've got to use your head. Keep the engine fairly small (say, 3hp or less), keep the speed fairly low, and don't lose sight of what you're building. You are building a vehicle to carry your butt around, not a wall or shed. Don't nail it together, don't just fire a screw or two in each joint. Bolt it together, using washers and locknuts. Put much thought into how you're going to attach things like axles and wheels, and get an adult to give you a hand if you're not sure about something.
