chainsaw clutch?
foggy34
i want to know if i can use a chainsaw clutch with my 31cc weed eater. and what speed i could get? i weigh 140
thanks.
Blazkowiez
Kart Aficionado
Houston, Texas
Wouldn't even begin to know the answer to that question. We don't know the size of your tires, what your gear ratio is, what your kart weighs, what terrain, and what rpm it caps out at.
George45
what kind of chainsaw was it?
i have a still clutch/chainsaw i was wondering i could find a bell housing and sprocket for it and use the chainsaw engine of course.
DustinWolfe
Meridian, Idaho
its possible it might work i have a 12hp chainsaw but youd have to modify it cause cutting chains and motorcycle chains are driven two different ways.
A 31cc weedie engine likely won't do much for you (unless it's mounted on a skateboard). As for the clutch question- a)as long as it fits your engine's PTO shaft, and b) as long as you have a way of mounting a proper drive sprocket on the drum.
