Chain & Oil Questions
Squiddy202
Manco Dingus
Eastern Pennsylvania
So my sister’s friend who is a mechanic for the big karts otherwise known as cars told me two things:
1. My oil shouldn’t really be black. When I changed it after the old owner I probably just washed crap down into the clean oil.
I can change my oil, especially with the hose the previous owner added to the engine.IMG_2004.jpeg
It is visible in the corner of that picture, I’m too lazy to go out to my boiling hot shed and get a better picture for a side tangent. Either way, I can and will change the oil. The real question is the chain.
They said it was too loose (it is) and I need a new one. I measured it and it seems to be 428 but it isn’t even 1/16” over a half. I noticed these bolts on my jackshaft:IMG_2033.jpeg
They go into slits on the underside. I am wondering if I slide that back while also sliding the engine back to keep the belt good if I will have fixed my problems.
P.S. My tape measure had markings smaller than 1/16” for like 3” at the beginning. I don’t know what they were but the chain was still at 1/2”.
Look carefully at the chain links, maybe even clean then a bit. Every other or so link should have a chain size number on it.
If your JS can slide back to tention the chain thats how you tighten it. BUT your engine must slide with it. The spacing for the CVT belt must stay the same.
Squiddy202
Manco Dingus
So at what point do I buy a new chain? I have what seems to be borderline perfect pitch, but how do I know when it isn’t ok?
To check chain wear i like to pull the chain at the rear most point. Away from where the chain starts to engage and leave the sprocket.
It should be rather tight. If you can pull the chain up off the teeth its wore out.
Take the chain off and lay it on the ground. If it bends sideways like the one on the left, its wore out.
Squiddy202
Manco Dingus
Thanks, will do. I’ve never seen that before!
Squiddy202
Manco Dingus
And yes the oil will get black. This is normal as the junk is suspended in it (carbon and bearing, block, piston and ring material). Your sister’s friend is a moron.
I mean to be fair it is dark black, pitch black and I haven’t changed it since I got it last fall. I think the time is the bigger thing.
Squiddy202
Manco Dingus
Quick question, I see no master link on my chain. People talk about breaking chains, but everyone seems to out a master link back in. Is there any way to put a pin back in with a chain breaker? Do chains just not have master links from the factory?
You can get one piece chains as a special order.
A master link is the way most everything else works.
Did you check both sides for the clip on the master?
No you can't put a pin back in after you break the chain.
Most every new consumer-grade vehicle; motorcycle, 4-wheeler, kart, mini-bike, etc. comes with a master link. It permits easy chain disassembly/reassembly for servicing and that’s good for the consumer---back when they used to do their own maintenance.
When you buy chain for a motorcycle for example, it’s usually bought by the precise link count per the original specification. That way the owner doesn’t have to break chain or fiddle around with it but just install it, add a master link and go.
Otherwise, you can buy chain in bulk, like 20 feet of chain or whatever. This is what a lot of us do for multiple karts and minibikes. Cheaper in bulk and learning to break your own chain is one of those man skills for your man card.
Use a good air filter. There’s comparatively low amounts of ring material, cylinder/piston/bearing particles suspended in the oil compared to outright dirt (in most cases). However, motor oil gets darkened quickly due to the combustion process. It is what it is and should not be used to gauge the oil condition.
It comes out dark brown to black for most oil changes across the board. If it comes out in chunks, like spoiled milk or thick like yogurt, that’s sludge and that’s a problem. Change your oil when it’s hot.
I assume the stock one doesn’t count as good?
Stock can be the best you can use, IF its the right one. You gotta picture of yours? Theres a few different versions.
I have a different setup now but this was what I used after my 'sTaGe OnE' filter sucked in the entirety of 3 tons of dust and ruined my rings...
The new one in the picture, it had the yellow accordian paper element filter, wrapped in a foam sleeve.
I can get a picture of the actual filter if you dont know to which Im referring.
Did you ever find your master link?
Your used motor oil (with normal use) should come out dark brown. I know some people will call that black, some will say dark brown or brown but individual descriptions like this devolve into semantics. The struggle is real.
Edited to add: I suppose it can be black, like totally cooked, hasn’t been changed in 10+ years and is full of contaminants but you’re not that kind of guy, are you?
The stock air filter is usually good or great even if it‘s just the kind that’s a 1 inch thick piece of foam. The major key is the black box that the filter sits in. The air box helps a LOT.
Has anyone mentioned that the Stage 1 cone racing filters are actually bug filters yet (in this thread)? Whitetrashrocker coined the term. 🏅
Squiddy202
Manco Dingus
No filter pics yet, I think it was the foam kind but I’m not sure. I’m wiriting this from my dad’s 68 VW camper on the way to a hobby shop a ways out, but my dad mentioned something. I have been using 10w-30 based on engine spec sheets. Is that still good advice for karting? I live in eastern PA and do like riding in winter sometimes. I do change my oil well, but I have no clue about the previous owner. When I first changed it I changed it cold I think. There is a good chance I just washed crap off the parts and into the oil. This will be my second change with the kart. Also, my aunt brought a new house recently to move closer to family. She found a thing of old 10w-30 that she won’t use. It’s still gold but who knows how old. Google says oil has an expiration date, does that apply to karting? I could also mix it with relatively new stuff. What would you do with the old oil?
Your aunts quart of 10-30 will be fine to use in your kart engine.
You can mix brands but dont mix weights.
Orileys and autozone take old oil.
Or if you know someone who has an oil burning heater , they will take it.
Oh man, you’re asking good questions. I thought about asking DIYGK members if they abided by the idea that oil has a shelf life or expiration date and their opinions on it. There’s always old (unopened) oil lying around and it’d be a shame to throw it out. Like you inherit the old oil or you sell the car that used 10W-30 and have a few quarts of 10W-30 leftover but it’s about 10+ years old.
I would bet that the expiration date really only applies to modern detergent oils with all the additives. I bet the ‘additive package’ goes stale but there is such a thing called non-detergent oil, but I think it’s for special use or antique engines or something....
Another option for used oil is the city/county dump. I don’t have a dump per se but it’s a public lot with dumpsters in it and a place to recycle. Near the back there’s a big vat for dumping your used oil into. That’s what I do after storing up a few gallons.
Most of the engines we talk about here use “10W-30”. Remember, the W stands for Winter and when it’s cold, the oil acts and flows like a 10 grade until it gets up to operating temperature. The 10 helps with cold (winter) starting but soon after our air-cooled engines get up to 300° F and it won't matter. I switched to straight weight SAE30 oil a few years back ...for reasons.
