Chain question
Racer2874
I have a predator 212cc running a centrifugal clutch and I belive the chain on it is too tight causing it too want to run off during idle. Does anyone have solution to loosening the chain? Or is their something different to do?
Atlanta, GA
This could be any one of a number of issues. Is it a new clutch? What brand of clutch is it? Can you adjust the chain tension by moving the engine on it's mounting plate? Is it making any noises? Can you post a picture of the set up? A tight chain won't typically make a clutch engage, unless there is excessive wear on the clutch bushing.
Racer2874
I said that wrong. It wouldnt run with the tension while tires on the ground but when I jacked it up the car immediately wanted to take off. Here is pics. It's on polyurethane bushings for motor mount
Atlanta, GA
That's a nice clutch. I am not personally familiar with it, so maybe someone else can chime in. Can you move the engine back to adjust the chain tension? If you can and do, and the clutch is still engaging, try to adjust the idle speed, or figure out how to service or adjust the clutch.
Are you saying that when it is on the ground the kart doesn't take off, but when it is in the air it does take off?
If this is the case, then it is normal. As long as it doesn't take off while sitting on the ground, you are all good :thumbsup:
