carter go kart wont move
cory95dylan
Hey there Im new too the go kart world. But recenty i got my son a carter go cart looks too be an older on non belt or chain driven and is a 2 stroke..
Needless too say it does not move the wheel is locked up. Previous owner thought it was brakes but the wheel is locked tight
Is anyone able to point me in the direction on what too and how too look into the brakes or the driveline
I do have the model number and serial number which i tried too look up but i got no information
Kelly Wood
The Mad Kartist
Salt Lake City Utard
Welcome,
Can you shot some pictures of the engine/drivetrain please? I'm sure there's help here but for that, we'd love to see what you're dealing with to point you in the right direction.
Wait.. is that the kind of weedwhacker setup with the loooong driveshaft and the small 50cc engine on top?
then it'd be a carter 1802-xxxx whatever xxxx (the color code) is for white ;)
if so, there's a small gear inside that driveshaft that, if not inspected and well maintained will lock up on you (caries)
so, remove the driveshaft, open up the two halfs and inspect, if nothing is broken, realign the cogs, regrease, remount then retry ;) make sure the bushings are tight and smooth ;)
see here for more details and partlists...
cory95dylan
I have pulled the axle and split the case. Everything seems too look as it should. No worn or broken gears. I thoroughly cleaned everything and replaced the old nasty grease. I havent put the motor back on yet but noticed that it stll doesnt roll freely. Which in would i think that it would. So looks like im gonna have to tear apart and try to go over everything again.:huh:
Did you check all the bushings & bearing while the axle was out? if just one of then is siezed or semi seized, the axle won't roll...
Another possible issue is the two halves of the casing may be pulling down too much, distorting one or more of the bushings, which, in turn, will clamp the bushings onto the axle; you may need a thin gasket between the two casing halves...
well, the worm gear is basically a "one way" gear
as soon as the drive shaft is in place, you cannot turn the wheels;
not without freewheeling hubs on them at least.
the pinion is trying to push the worm hundreds of times harder than it's trying to turn it;
that's by design. (huge gear reduction, slow running but with good torque)
Assemble the drive shaft, then turn the clutch (the bell in the upper end)..
Does the shaft on the bottom rotate?
slowly but without much effort?
Well.. then you're good!
