can the carburator idle... and not turn off if i dont take off right away
---------- Post added at 02:34 AM ---------- Previous post was at 02:30 AM ----------
ok..what happen if i use the liittle stick thing.. and turn clock wise on the carburator.. and what happen if i open the carburator....and what is the disadvantage.
---------- Post added at 02:37 AM ---------- Previous post was at 02:34 AM ----------
Clockwise to reduce gas flow and counterclockwise to allow more gas follow. This problem often occurs because your carburetor is flooding.
The brass color screw located below on the side of the carburetor, next to the choke lever is for the fuel and air mixture. Start by turning this screw (clockwise) until it stops. Don't turn it in tight, just until it stops. Next, turn the screw out two full turns (counter-clockwise). This is the factory setting. You should be able to start and operate the Go Kart with this setting. Once you have it running, you can adjust it. Never turn the screw more than 1/8 of a turn at a time. Turning it in too much will cause the motor to run lean at full speed and may burn a piston. Also, running too lean will cause a loss of low end power. Once you get the mixture set you can adjust the idle, it should be low enough that the engine doesn't vibrate. Finally make sure you have the choke lever down completely after the Go Kart is started and warmed up.
---------- Post added at 02:43 AM ---------- Previous post was at 02:37 AM ----------
cause if i turn too much the motor will bog out..and wont idle therefore it flooded with gas... if i close it it will be too lean ... and as far as i know...the stuttering to get to higher gears = higher speed i get that stuttering then it will be in higher gears which resolve in going faster... so i am assuming that i lack of low end power... so therfore what is the perfect setting for the yamaka kt100
