carb question
Cjhoward78
Ur engine is 2 stroke? I just thought of this, u cannot pressurize the cylinder due to the exhaust port and intake port being open at the same time. Nature of a 2 stroke:( no can do on the supercharger.
builder bob
MA
then why's it work on a 2 cycle nitro engine? is it because they expect u to be using a tuned pipe by the time u want a supercharger?
Cjhoward78
Well, I believe the glow engine supercharger does not provide real power increase due to this same problem. As u push the charge into the cylinder u achieve instant pressure loss through the exhaust port into the pipe. I don't find it possible to create even 1/2 psi. If anything u get better flow through the engine creating an increase (small) in power. I also think fuel economy will be reduce due to pushing the air/fuel right through the cylinder into the exhaust.
builder bob
MA
ya but the tuned pipe is designed to push the fuel back into the engine so wouldn't it still be increasing what is being burned?:confused: I definitely agree that the efficiency would go down
Cjhoward78
I agree but w forced induction, that would have to be one hell of a pipe. The real advantage of the supercharger is the ability increase the volume of air/fuel in the cylinder while also increasing compression ratio of combustion chamber resulting in larger power gains.
builder bob
MA
ok so I guess I can't make a supercharged weed eater... darn. I still want to try and make a supercharger though and put it on my 49cc 4 cycle engine. I could do it if I could get stupid autodesk inventor to download onto my computer! i do not like windows 8.
