My carb keeps overflowing with gas, and pouring out of every hole. I have replaced the O-rings but havent tried a full rebuild kit, wanted to see if anyone had some ideas first. The only changed I have made were to where its at. I put the engine on a mini bike instead of a go kart and un mounted the gas tank so its higher, not sure if that might have anything to do with the pressure but I doubt it. I have a vm22 Chinese mikuni.
Now for the 2nd problem, the backfiring. Before this whole gas thing and even now if I take the carb off and use starting fluid it always backfires. I have put new cam in, chromoly push rods, 26 lb valve springs and checked my valve lash god knows how many times. Ignition is advanced by 4 degrees also. I have tried using stock cam and no ignition timing to no prevail. I have heard that with high compression (I have thinner head gasket and extended piston rod 0.040") I believe its because of compression but again if anyone has ideas I would like to still be able to pull start it, havent found any reasonably priced starter kits.
