Carb issues. Help quick please!
manco36
Once again I will look to this awesome forum to help ke solve yet another problem.
8HP Briggs and it has always run great. I recently cleaned the carb (for the 4th time since i've owned the kart) but I'm having starting issues now. When I pull start it, fuel starts leaking out of the bottom of the carb and it won't even come close to turning over. But if I unscrew the 1st short jet and drain the fuel, wait a few mins and try to start it, it will start on the second or third pull. Why would it be leaking gas out of the bottom of the carb all of a sudden.
I did recently replace the fuel lines and fuel filter fyi.
I have a big riding day tomorrow and I'm hoping someone here can help ke quick!
Thanks in advance!!!
manco36
Also, it doesn't start leaking fuel out of the bottom of the carb until i actually attempt to pull start the engine. It sat in my garage all day and didnt leak a drop of fuel until i tried to start it.
I have wrapped my head around the issue and can get it staryed but this is crazy what i have to go through. Need help asap! Thanks!
Is the bowl on correctly, seal not damaged, same with the bolt washer seals.
Is the float working properly?
A few things to check....
Edit: Oh I just asumed this was a clone.....
sorry.
manco36
The inside of the carb is in excellent shape. I bought all new gaskets from a local small engine shop so I know they are sealed very tight. The bolts are all great and I replaced the old washers with new ones. The inside of the carb is very clean and in great shape. The needle is installed correctly, the float is in great shape with no leaks or cracks, the jets look brand new and are free of any debris. There is no rubber O-rings inside of this carb.
It is an up-draft type of carb. Today I did a lot of riding and if I sprayed some starter fluid in the intake it would start first pull. After the motor was warmed up, it would start first or second pull "without" starter fluid. But if the kart sits for a few hours, when I go to start it, again the carb leaks gas out of the bottom and won't start unless I take the incoming fuel line off and then drain the fuel from the carb by removing the first small jet. It's really irritating and I don't want to have to remove my air filter and spray starter fluid every time I ride.
I've toyed with the idea of installing a fuel line shut-off valve between the fuel filter and the carb and when I'm done riding cut the fuel and let the engine run itself out of gas. But I'm skeptical that it would work because it only leaks when I start pull starting. It can sit for hours without dripping any fuel until I go and pull start it. I've rebuilt many of carbs in my time and I just can't figure out what's going on here.
Please everyone, give me your thoughts and ideas!!
rocketkart
florida
may just be the float sticking. when it starts to leak out try tapping the carb with the end of a screwdriver, it should stop. more thin likely it's just the float sticking and overflowing. thos up draft type of carbs are known to do that all the time and are a pain in the @$$.
Poboy kartman
Senior Moments Member
White Settlement Texas
That was my thinking as well. I have an old 5 hp Clinton outboard with the same gremlin......
manco36
I actually did try tapping with the end of a small ratchet yesterday. Only tried once though. I'll give it another shot. I actually liked this carb until now because it's so easy to take apart and clean compared to my other Briggs motor. Thanks, I'll report back
manco36
Tapping is not doing the trick. When I put the two carb pieces back together I can shake it and here that the float is moving and not stuck.
As for the float height being wrong, I've been using this carb for about two years and have never had this issue. I don't think the float height changed when I put it back together. The only reason I actually took the carb apart was because after an oil change, I put too much oil back in the motor and it leaked into the carb from the PCV Hose (I think that's what the rubber hose is called) and into the carb which caused a lots ofsmoking.
I'm very surprised and baffled by this problem. Usually between playing with things and getting info from you guys on this site I can get everything fixed. I've just never seen nothing like it.
Any more ideas out there??
rocketkart
florida
take the carb off the engine. use a clean fuel hose to hook to the carb and hold the carb upside down and blow in the fuel line to see if the float needle valve is working/closing properly. if you can blow a lil bit of air in the carb while the carb is upside down thin the needle valve is not closing properly.
manco36
I just came in from playing around with it. Yesterday when I sprayed starter fluid in it, it would start right up and run pretty good (flawless 1 hour riding session.) I tried doing it just now and it just burned the starter fluid and the motor cut out. So It's not even working with the starter fluid now. I will go out and remove the carburetor and do what you said and report back. Thanks for your help.
manco36
Ok, I did the test. When I flip the carb upside down, It's impossible for me to blow any air into it.
rocketkart
florida
ok take the float out and see if the float may have a hole in it. one way of testing this is to pour gas in a small bowl and set the float in it to see if it starts to bubble. other thin this idk what it can be. or shake the float if You can hear gas sloshing around in it, Replace it. the more that i think about it the more i think this is the cause. i hade a very similar problem a few yr's back. you need to be verey thorough on this. good luck :thumbsup: http://www.mfgsupply.com/smallengine/smengcarb/smengcarbkits/smengbscarbkits/22-11959.html
manco36
Yea I've tried that to make sure. That's what I thought as well. I'm so irritated I think I'm ready to buy a Predator engine and sell the Briggs
