Carb advice
The Overpaid Baby
Gulfport Ms
I need a new carb for my shelf motor. It's a gx 270 9hp. My question is, can I put a gx390 carb on the 270? Also, if I can, would you suggest it? What are the pros and cons? Also, if the carb for the 13hp works and possibly improves performance what other parts can be interchanged between the two motors? You guys are bad to the bone, this forum is a treasure trove of Karting info. :thumbsup::cheers2:
Yes a GX390 carb does fit and does add some extra power. What's wrong with your current carb though?
